    Forum Shop
Sign in to follow this
Palmtree
Outboard foul
As our outboard is in the water for the season we tend to build up foul on the leg & prop. In past years I have scraped it off with a bit of wood. Is there a better solution for cleaning and some coating to protect it for next year?
Ian
Hi Ian there is an antifoul that is made for outdrives and outboards as it is made for aluminium, you should be able to get it from Norfolk Marine.
Robin.
Oxalic acid is good for cleaning off, I then coat in a black antifoul as above from Nearest & Dearest.....
Not to worry Wildfuzz, I have the same issue..
and was going to ask a similar question, so all is not lost..!
(Could I have just saved your.... bacon?:facepalm:
Create an account
Register a new account
Sign in
Sign In Now
