BroadAmbition Posted April 17, 2017 Share Posted April 17, 2017 Surplus to requirements One Vanette 4021 in full working order, jets for LPG Propane - However if you want auto ignition you will need to acquire / fit the button and spark driver box. After fitting a normal gas tight test would be wise of course Free to a good home but with a suitable donation to forum funds of course Griff Quote Link to comment Share on other sites More sharing options...
smitch6 Posted June 28, 2017 Share Posted June 28, 2017 has it got the auto shut off valves pls? Quote Link to comment Share on other sites More sharing options...
Viking23 Posted June 29, 2017 Share Posted June 29, 2017 6 hours ago, smitch6 said: has it got the auto shut off valves pls? Looking at the underside, there appears to be a thin copper pipe going to each gas valve, which to me, implies it has flame failure. However I am no expert. Quote Link to comment Share on other sites More sharing options...
tjg1677 Posted June 29, 2017 Share Posted June 29, 2017 Yes the thin copper tubes appear to be the thermocouple to each burner for the flame failure device. It looks like it had electronic spark ignition fitted in the past but has been removed, hence the hole in the middle between the burner knobs where the button was sited. 1 Quote Link to comment Share on other sites More sharing options...
Vaughan Posted June 29, 2017 Share Posted June 29, 2017 According to the label, it will burn on Propane or Butane, but the appropriate jets would need to be fitted. It definitely has flame failure. Two practical hints : 1/. The primary air intake is actually around the bottom of the burner cap and can become blocked with cooking fat. For the same reason, never use a foam type aerosol oven cleaner, or this will block off the air. 2/. On top of each burner are two screws and it is best to loosen these by half a turn. Otherwise they get rusty and then you can't get them off when you want to clean the burners. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted June 29, 2017 Author Share Posted June 29, 2017 Yes it has got FFD's passed the BSS every time Griff Quote Link to comment Share on other sites More sharing options...
Biscotte Posted January 11, 2022 Share Posted January 11, 2022 Is this still available by chance? 1 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted January 11, 2022 Author Share Posted January 11, 2022 Unfortunately for you - Sorry no, went ages ago now, can't even remember who to tbh Griff Quote Link to comment Share on other sites More sharing options...
