DaveB Posted November 3, 2017 Share Posted November 3, 2017 No, not a sewing question Would anyone happen to know what size thread the water temperature sensor hole is on a bmc1500? It's in the side of the thermostat housing on the head. As I have a new sensor that's apparently 1/4 npt whatever that is and it's too small so I need to get an adapter, if anyone knows I would be eternally grateful Quote Link to comment Share on other sites More sharing options...
ExUserGone Posted November 3, 2017 Share Posted November 3, 2017 5/8" unf springs to mind from my old 2.5bmc days. 1/8npt is a common american pipe size, some npt match with bsp but lots are 1 TPI different, they also use different pitch angles on the thread form (55 & 60 degrees but can't remember which way). There you go an answer and an education. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted November 3, 2017 Share Posted November 3, 2017 3 hours ago, Dilligaf said: 5/8" unf springs to mind from my old 2.5bmc days. 1/8npt is a common american pipe size, some npt match with bsp but lots are 1 TPI different, they also use different pitch angles on the thread form (55 & 60 degrees but can't remember which way). There you go an answer and an education. Pretty certain that's right ie 5/8 unf , as for a reducing bush I'd try ASAP supply's . Quote Link to comment Share on other sites More sharing options...
Vaughan Posted November 4, 2017 Share Posted November 4, 2017 It is a tapered thread, as well. 1 Quote Link to comment Share on other sites More sharing options...
JohnK Posted November 4, 2017 Share Posted November 4, 2017 Wikipedia says ....Screw threadPer ISO 1222:2010, the current tripod screw thread standard for attaching the camera calls for a 1/4-20 UNC or 3/8-16 UNC thread. Most consumer cameras are fitted with 1/4-20 UNC threads. Larger, professional cameras and lenses may be fitted with 3/8-16 UNC threads, plus a removable 1/4-20 UNC adapter, allowing them to be mounted on a tripod using either standard.Other websites seem to agree. I have no knowledge of the subject but woke up early so spent a bit of time Googling it. 1 1 Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted November 4, 2017 Share Posted November 4, 2017 If your local pop to Boulter’s in Horning as I had the same problem and they found me an adaptor. Great local company who are always willing to help definitely gets my vote. Doug. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 4, 2017 Share Posted November 4, 2017 1 hour ago, JohnK said: Wikipedia says .... Screw thread Per ISO 1222:2010, the current tripod screw thread standard for attaching the camera calls for a 1/4-20 UNC or 3/8-16 UNC thread. Most consumer cameras are fitted with 1/4-20 UNC threads. Larger, professional cameras and lenses may be fitted with 3/8-16 UNC threads, plus a removable 1/4-20 UNC adapter, allowing them to be mounted on a tripod using either standard. Other websites seem to agree. I have no knowledge of the subject but woke up early so spent a bit of time Googling it. I may be wrong but I believe you meant to post on this thread John Jay Quote Link to comment Share on other sites More sharing options...
JohnK Posted November 4, 2017 Share Posted November 4, 2017 I may be wrong but I believe you meant to post on this thread John JayHaha, sorry. That does explain why I thought there were less posts than when I looked before!Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
DaveB Posted November 4, 2017 Author Share Posted November 4, 2017 Thanks to all I should be able to source an adapter now Quote Link to comment Share on other sites More sharing options...
