Once In A Lifetime Opportunity
High6
Wonder why NO engine.
5 minutes ago, MauriceMynah said:
Too big for the broads.
Phew!!!
Too big for most canals, even if you fitted propulsion. 74ft and wide beam. Only any good as a house boat. Moving it will not be cheap either.
21 minutes ago, TheQ said:
It looks like the top "cockpit" should fold down, which means it would go under the bridges. would look good in Hickling broad... :default_biggrin:
If you moored on the bottom of Hickling Broad would you get moved on?
2 minutes ago, LondonRascal said:
I never have been one to look for boats for sale on Ebay. Now I see how many there are - even 'speed boats'! :default_cool:
Plenty of choice to increase your fleet some more Robin :default_norty:
3 hours ago, JennyMorgan said:
A good coastal delivery job for Team BA then?
What are they going to tow it with? It must go a hell of a weight! John White Boats builds steel canal boats. Even Robin's 1000hp with it's set up will struggle with that on the end of a tow. Two words come to mind "White and Elephant"
1 hour ago, LondonRascal said:
But you can get speed boats on there and everything..But I like the projects for a couple of hundred pounds.
https://www.ebay.co.uk/itm/Classic-Broom-Speedboat-with-trailer/192514297420?hash=item2cd2bf0e4c:g:OysAAOSwafta11l8
I think that should go on the back of a truck, don't fancy having that trailer attached to my car.
Quote
I did see a big wide beam barge on the witham once called enigma, it had a large wheelhouse on top on hydraulic arms that folded over the back to sit behind the main hull, it was just folding back up after coming through torksey lock when I saw it, very impressive design.
I will have to try and find some piccies of it.
Found it!
Edited by Smoggy
Found piccie.
