Happy Jax 3 Posted November 20, 2007 Share Posted November 20, 2007 I am looking to install a water tank level indicator. (You can guarantee you will run out of water when it is most inconvenient). I am a little bit nervous of cutting holes in stainless steel tank to fit a sender unit. How can you ensure that no swarf will drop into the tank? I have found a company Henderson Plastics that supply a kit for this purpose, it uses an inline pressure sensor to be installed in the outlet pipe adjacent to the tank. Has anyone used a system like this? If so how accurate is it? Can anyone advise of any other suggestions or options available? Your help would very much be appreciated. Col & Lou Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted November 20, 2007 Share Posted November 20, 2007 Plenty of Vasaline or non toxic grease on a GOOD quality hole saw, go slowly, clean the swarf and Vaso off 3 or 4 times during the process and fit a strainer inline before the water pump and you will be fine :-D :-D Quote Link to comment Share on other sites More sharing options...
jillR Posted November 20, 2007 Share Posted November 20, 2007 ive just bought two neodymium magnets on ebay i can recommend them unless you have a pace maker as they are very very strong. the ones i bought are 20mm x 10mm disc with a hole through the middle. i bought them to use for tools over board but i think it could work well for your job. i bought two for £7.50 inc p +p jill p.s. you will have problems removing the swarf from the magnet when my two magnets got together i had to use a knife to separate them Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted November 20, 2007 Share Posted November 20, 2007 Sadly Jill, non ferous tank, though I agree magnets are helpful when working with ferous material.. :-D :-D Quote Link to comment Share on other sites More sharing options...
jillR Posted November 20, 2007 Share Posted November 20, 2007 lol just too eager to brag about my new toy jill Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted November 20, 2007 Share Posted November 20, 2007 lol just too eager to brag about my new toy jill Rightly so Jill, you can find a complete tool kit for free with a good magnet, a good investment, and you can make pretty patterns with iron filings and a piece of glass too. :-D :-D Quote Link to comment Share on other sites More sharing options...
Happy Jax 3 Posted November 24, 2007 Author Share Posted November 24, 2007 Thanks ANTARES_9 Have you had any experience with the inline pressure sensor as a level sender unit? May save drilling holes in tank. Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted November 24, 2007 Share Posted November 24, 2007 Well, if sensitive enough to sense a "HEAD OF WATER" then they should be OK but I'm not familiar with them. Quote Link to comment Share on other sites More sharing options...
