Guest Posted November 27, 2007 Share Posted November 27, 2007 hi peps looking for a good cheap and simple charging system we can use on the boat any ideas? Quote Link to comment Share on other sites More sharing options...
thirdmate Posted November 27, 2007 Share Posted November 27, 2007 Jonny I assume you mean something to trickle charge in your absense when Curlew is moored up ? Wind power is always an option. Plenty of wind driven generators around from around £35.00 upwards Quote Link to comment Share on other sites More sharing options...
Guest Posted November 27, 2007 Share Posted November 27, 2007 yep thats right our bilge pump seams to be zapping the batteries dead so for now the car charger is on there while hooked upto shore power. but looking for something simple to put the batteries to full charge when were not on the boat saves spending more cash on batteries that last less than six months Quote Link to comment Share on other sites More sharing options...
Heron Posted November 27, 2007 Share Posted November 27, 2007 I too am interested in looking at wind power to keep batteries charged but have not had a lot of luck finding sites, anybody know any links? Quote Link to comment Share on other sites More sharing options...
Guest Posted November 27, 2007 Share Posted November 27, 2007 would they only be like a little trickle charge like the little solar panels or will they but loads more charge back into the batteries at any one time. Quote Link to comment Share on other sites More sharing options...
Brian Posted November 27, 2007 Share Posted November 27, 2007 Any wind or Solar power would be a trickle charge, unless spending £100s Solar is rated in milliamps, while a car charger would start at 2 amps. Charging capacity Wind and Solar are ideal to keep the battery Topped up so to speak. Quote Link to comment Share on other sites More sharing options...
senator Posted November 27, 2007 Share Posted November 27, 2007 Jonny, Am I right in assuming you have shore power at the marina but currently no mains charging system on the boat? If so how many banks of batterys are you looking to charge. Ian Quote Link to comment Share on other sites More sharing options...
Guest Posted November 27, 2007 Share Posted November 27, 2007 yes Ian mate we do have shore power at the yard and is currently connected we have got a car battery charger charging the batteries on a timer 2hours on 2 hours off. should be ok but was thinking how much it would cost to get a charger fitted to the boat. Quote Link to comment Share on other sites More sharing options...
senator Posted November 27, 2007 Share Posted November 27, 2007 http://cgi.ebay.co.uk/CONNECT-AND-FORGE ... dZViewItem Cant work out how to put in a hyper link but if you paste this into the address bar it will get there. Don't know if they are any good, sure someone with more technical brains will be able to let you know but £50 seemed reasonable for a marine charger. Ian Quote Link to comment Share on other sites More sharing options...
Stranger Posted March 7, 2008 Share Posted March 7, 2008 better idea Jonny cure the leak so the pump stays off longer http://www.boatus.com/howto/howto_lib.htm Quote Link to comment Share on other sites More sharing options...
Guest Posted March 7, 2008 Share Posted March 7, 2008 Thanks Dave but how does that help me? Quote Link to comment Share on other sites More sharing options...
