    Forum Shop
Sign in to follow this
RedRover
Air venting in engine compartment
Can you help me please? How much air venting does an engine need to run efficiently? mine at the mo is around 6" x 4" is that enough?
There is a formula Barry, if you check how many CFM of air your motor uses, Peachment should be able to tell you, I will work it out for you.
David
Thanks david,it should'nt be a difficult job just cut another hole and screw a vent on it.as long as it is above water,don't want to be another casualty under water.
Indeed Barry, but no point in cutting a bigger hole than you need :-D
Create an account
Register a new account
Sign in
Sign In Now
