    Forum Shop
Sign in to follow this
smitch6
through hull fittings
Hi
i've pulled the boat out for work etc and none of my hull fittings have taps that work :o
so while it's out i want to sort all them out, but i have a few questions please
i have twin ford 2700 straight 6 diesel engines, do i need the scoop fittings? or can i just replace them with normal flat fittings (with taps ob lol )
also the sea toilet will need 2 holes as the loo used to be in the front but i've moved it to the back (hence more holes to be filed as in other thread lol)
is it best to have a scoop fitting for this? as i noticed on out journey down it was struggling to bring the water up (altho it did have to pull it quite some distance altho it's fine when we're standing still)
also whats best these days plastic or bronze for these fittings?
also i think i need strainers on my engines don't i? if so what sort please
(sorry as you can tell i've never even looked at this sort of thing before)
right just ordered all the fittings with strainers and 1/4 turn shut off valves etc
so at least it'll be safe now in the event of a failure
one question though please if i may is what do you use to seal the fittings?
on the ones i took off it looked like plumbers mate was used.......
is that the right kind of stuff to use on all the hull under water fittings?
thanks
It's simple - for insurance purposes use SIKA 291 or 292 (BLACK) below the waterline for all purposes. The numbers 291 and 292 refer to the uktraviolet retardation of the product. :wave
don,t use silicone below the waterline ,if you do sink your insurance won,t payout!! :wave
guide price... http://www.uksealants.co.uk/product.asp ... 4QodqhX60w
Forgot to add use ptfe on the threads with a small wipe of the sealant on the last two threads.
Create an account
Register a new account
Sign in
Sign In Now
  • NBN Mobile App
    Our new mobile app is available now on Android and iOS!
    Get it on Google Play
