    Forum Shop
Sign in to follow this
Guest phill
Aquafibre Ideal 40
Hi
Can any one help we have a aquafibre ideal 40 1980 ?? fitted with im told a bmc 2.3 ?? The prop on the boat is a 11" and it should be fitted with a 16"
Does any one Known what size it should be as we need a new one...Thanks
Almost impossible to say without more info like the output your particular BMC 2.3 achieves, the gearbox reduction and the displacement of the boat I’m afraid. Unless somebody has a similar craft or Clive has or has had something similar on his fleet that is.
Hi Phill,
BMC made a 2.2 and a 2.5 but I dont think that matters too much, as they are fairly similar..
I have only known Ideal 40s to have either 1.5 or 1.8 BMC engines but the most important thing is to find out what gearbox
you have and wether it is direct drive or on a reduction then you can decide which prop is best suited. I dont know too much about working these things out but there are others here that can.
Welcome to the forum ice slice
Why do you want to change the size? are you making correct speed at full revs? are you making full revs at wide open throttle in gear? if not what revs speed are you making as this will be a good indicator of the size you need.
Create an account
Register a new account
Sign in
Sign In Now
  • NBN Mobile App
    Our new mobile app is available now on Android and iOS!
    Get it on Google Play
