Palmtree Posted January 30, 2008 Share Posted January 30, 2008 Hi, I am about to install a shore power system, with one two 240v sockets and a feed to battery charger. The consumer unit (fuse/trip/junction box), are there any units for boats that are something like IP56 rated. Ian (5 weeks and counting) Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted January 30, 2008 Share Posted January 30, 2008 Hi Ian, if you're going for a good quality compact easy fit why not look at an all in one battery charger, with propper 3 stage and float, ring main connection in an easy to fit unit and designed for marine use. As far as I am aware even the marine stuff is not really designed for "wet" areas so you may have to look at industrial factory process kit if that's what you're after. Quote Link to comment Share on other sites More sharing options...
VetChugger Posted February 6, 2008 Share Posted February 6, 2008 Alternatively for an easy and compact solution that you can hide away when not in use have a look at these... http://www.waudbys.co.uk/products/details/62.html I have one and it works very well. Trevor http://www.normanboats.co.uk Quote Link to comment Share on other sites More sharing options...
Palmtree Posted February 6, 2008 Author Share Posted February 6, 2008 Hi, Trevor,we have one of those already and they did a good job last year. Our one is not as good as the plugs fit down the centerline so the plug leads get in the way of the next plug. Your one is better as the plugs are orientated across the unit. David, I have now ordered a Sterling 1250CED unit Ian Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted February 7, 2008 Share Posted February 7, 2008 "Ideal for use on 33 – 44ft boats.", nothing like having something in reserve Ian :-D :-D Quote Link to comment Share on other sites More sharing options...
