    Forum Shop
Sign in to follow this
brandenjg
Mariner 2hp 2m 6a1 Service manual and oil mix?
Hi everyone, I've just got myself a little mariner outboard and i was wondering what oil mix it needs. Ive been told that the factory recommended is 100-1 but after doing a search on google, alot of people are saying 50-1. I was hoping someone on here could tell me the right mix. I'm also looking for some sort of manual for the outboard for reference if i need to do any repairs or maintenance.
Im going to be taking it and the boat down to wells wednesday to test it out ( Mainly because i see no reason to buy the toll for the broads till i'll actually be using it after april)
As usual any help will be greatly appreciated.
Thank you
Hi,
I now have a 3.3hp Mercury which I will be using a ratio of 50:1. I should think this would suit your engine too. With regard a manual, I don't know if sending a PM on this link would be of any use to you?
(mods, sorry for cross linking to another forum, but I didn't think it's be too much of a problem in this case)
Thing is, dependant on age, it could be either, but running it on 50:1 will do no harm especially if you are running it at high revs. As for the manual, as these little ones are all basically Tohatsu rebadged here is a PDF of the Tohatsu manual which should help.http://www.tohatsu.com/tech_info/own_man_pdfs/Toh2-5A2_3-5A2_3-5B2.pdf
Hi,
Forgot the link, sorry! http://www.ybw.com/forums/showthread.php?t=291075
Yes, very good advice.
I've had the Yamaha 2B version (another clone of the same engine) for nearly 20 years, and have always run it on 50:1, instead of the specified 100:1.
Small two stroke outboards were often marketed as " 100:1 ", to keep up the competition between manufacturers boasts, ( similar to car oil change limits going up, sounds good, but not as good for the engine's long term life).
My Yamaha 2 and my Evinrude 4hp twin run very sweetly and cleanly on 50:1, and quite a bit cooler than when I tried them at 100:1.
That amount of extra lubrication will do no harm, and will undoubtedly result in less wear, especially if run at above half throttle, as Antares said...
Create an account
Register a new account
Sign in
Sign In Now
  • NBN Mobile App
    Our new mobile app is available now on Android and iOS!
    Get it on Google Play
