    Forum Shop
Sign in to follow this
RedRover
Loo Leaks
Does anyone know where i can get older toilet seal spares from, mine are the foot lever type and the leak is coming between the bottom of toilet to holding tank.Ta?
Barry
If it is the flat type then you can make you own from either rubber or cork I would think.
Rubber can be puchased from Walker Rubber on Sweet Bri Ind Estate off the ring road in Norwich
Barry
What do you mean by the flat type ,paul?
Hi Barry,
Sorry for the late reply Just seen your question.
I got mine from Norfolk Marine at Wroxham
Good luck with the replacement
Its an orrible job
Rod
Flat type Barry is just a flat piece of rubber cut to the right shape - bit like a head gasket on a car.
I are assuming the leak is between the bowl or pan and the tank???
Yes,Paul, bit worried that when i unscrew said nuts something will fall in pan and i have to put my hands in to retrieve it, UGH Pooo,sorry for the pun. :o:o:o Name 0f toilets are Traveler..
Barry,
The bottom seal you are talking about is a specialised fitting so I'm afraid Pauls suggestion of making your own will not work.
It is made of a softer type of rubber seal more like a sponge than a head gasket as it has to have a degree of flexability.
The bolts will not drop into the holding tank they will come off in your hand.
If any of these bolts are damaged then I'm afraid I did struggle to find the replacements for them and ended up modifying some readily available ones from a DIY place myself. (10 mins work with a metal file)
I would recommend a good pump out and flush from one of the bigger yards before starting work on this job as you will be in very close proximity to an open holding tank. YUK
As said in the previous post I got my seals at Norfolk marine Wroxham.
I did cause a bit of a stir when I walked in one fine day with a rather dirty smelly worn bit of rubber seal in a plakky bag and asked for a replacement and did they want me to get it out of the bag to show them :naughty::naughty:
Rod
Ha,Ha, Thanks Paul,Rod for your help will try to remove toilet this weekend one good thing is you can do it whilst boat is in water. :o:o:wave :-D :-D
Create an account
Register a new account
Sign in
Sign In Now
