Sea Toilet Wont Flush ? Post up your questions here.
Should a sea toilet hold water in the bowl?
I assume it should but for some reason white ladys seeps away into the holding tank, if you switch over to the sea outlet it still seeps away. Thpught about putting an upwards pointing loop in the outlet pipe but cant get it in anywhere.
Any suggestions?
Ian
Our electric one does the same Ian.
But the best Electric Lavvy I have seen is on Tamara you have a menu of flushes; I kid you not.
This gives the option of leaving water in the bowl or not, I suppose water in the bowl is not a good idea on a heeling yacht.
  • 1 month later...
Obviously could vary with make and model, but I have had this discussion and am told it should, and when it leaks away it's time to change the seals, not had the courage to tackle the job yet ( on a Mansfield dump thro) but am told it will ease the pong in the summer
