senator Posted May 19, 2008 Author Share Posted May 19, 2008 Don't mind at all, did post last night but the connection crashed when I pressed send, As to the dinks this is a possible, there were some very slight dinks on both props which amounted to little more than a slight burr, I filed them off rather than sending the props away to steel developments. Maybe I should have sent them off to have the pitch checked and get them proffesionally done. For now I will live with them as it has no effect for 99% of my boating time but I would like to say thank you for everyones head scratching and brain stormming. As an aside I am now thinking of fitting a silt light to White Lady for use in the marina at anything short of half tide, hopefully though the prommised dredging will have been done by the time I get back there. Ian Quote Link to comment Share on other sites More sharing options...
Jim Posted May 21, 2008 Share Posted May 21, 2008 Hi Ian, It will be interesting to see what the problem was when you finally get it solved. Congrats on a perfect diagnosis of my hub slip David The new prop is on and the yard confirmed that the old one slips a bit under heavy loads only. Got to try her out yesterday and I'm happy to confirm that there is no slip now under the heaviest of loads Breydon here I come again! Quote Link to comment Share on other sites More sharing options...
