Heron Posted July 29, 2008 Share Posted July 29, 2008 When leaving a boat on its mooring, not expecting to use it for a couple of weeks, is it best to leave the water tank full, empty or doesn't it matter? Ken Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted July 30, 2008 Share Posted July 30, 2008 Unless you have the following set up and follow the following fill up regime the Pete's advice is sound. Always run the hose for a couple of minutes before using it, use the water to wash the first foot or so of the hose at that time, use purification tablets at the correct dose, fit a Silver filter to remove the taste of the chlorine and change it regularly. I always keep my tank as full as possible at all times unless I want to reduce weight and save a few bob on diesel on a passage but that doesn't really apply to much on the rivers. Quote Link to comment Share on other sites More sharing options...
kfurbank Posted July 30, 2008 Share Posted July 30, 2008 Not sure if its right or wrong, but here is what I do. I always leave the tank fully topped up all year round. I add Aqua tabs at the correct doseage to purify the water. I only use the onboard water for washing up and showering, using bottled water for any drinking, even for boiling water to make coffee etc. About once every 6 weeks I completely drain the tank down and then refill it. To aid with this I have installed a T piece just after the outlet from the tank. One side of the T goes to the water pump, the other side goes to a valve that can be opened to drain the tank completely without having to run the water pump. The tank when emptying goes into the bilge, which is also a good test for the bilge pump setup. I should point out for those worried about pollution that I have a separate captive bilge for the oil and diesel drips from the engine. The main bilge contains only river water ingress past the stern gland and rain water from the rear door foot well which drains into the bilge. It also contains an oil absorbant mat just to be on the safe side. Quote Link to comment Share on other sites More sharing options...
Gordon Posted July 30, 2008 Share Posted July 30, 2008 Hi Ken, Being a savage I don't tend to do much at all, not come to any harm yet just use the filter for drinking. Lets face it there is no way Jenny would let her dog drink it if it was at all suspect I do try to keep it full when left though. Small quantities of water can become putrid. Might be down at the weekend, not sure yet. Quote Link to comment Share on other sites More sharing options...
Guest stopper1941 Posted July 30, 2008 Share Posted July 30, 2008 When i was boating on the canals we carried our own hoses, but even then i used toput the first foot of the hose in a plastic container containing a dilute solution of bleach and then ran the water for a few miutes before filling the tank.collapsible hoses do not taske much room. brian soon Quote Link to comment Share on other sites More sharing options...
Mowjo Posted July 30, 2008 Share Posted July 30, 2008 After seeing the way the water hoses are treated by some people I now carry my own blue hose, it's only a 10mtr one but it does the job, cost me 50p a mtr from the caravan shop, it broke my heart when I had to pay nearly £10 for the fittings though from B&Q still it will fit any tap now, so I spose £15 isn't that bad, on emptying tanks, I've never emptied any of mine and I don't use steralising tablets either and I'm still here, I left it all winter this year and it was fine, but then I only use it for making tea, washing and washing up, I carry a 5ltr bottle for drinking and I always fill that up at home,,,, Quote Link to comment Share on other sites More sharing options...
Heron Posted August 5, 2008 Author Share Posted August 5, 2008 Thanks for your replies. Some useful points to consider. Ken Quote Link to comment Share on other sites More sharing options...
Guest Posted August 5, 2008 Share Posted August 5, 2008 Mowjo, Just a question - pardon me if I'm being thick - but with you various tap attachments, do you remove the hose from taps at boatyards and fit your own and replace theirs afterwards, or how do you do it? Nigel Quote Link to comment Share on other sites More sharing options...
senator Posted August 5, 2008 Share Posted August 5, 2008 The Marina hoses are fine providing you follow Davids advice, run the water for a couple of minutes if the hose has been standing, then wash down the first couple of foot to make sure you are not putting contamination in your tank. Something else worth considering though is that water even accross the UK is very different in mineral content, even though the water is totally safe to drink it may still be different to what you are used to and upset your stomach a bit. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 5, 2008 Share Posted August 5, 2008 Senator, How right you are.....in Lowestoft we have two different sorts of water, (well four if you include those either side of Mutford Lock Bridge !!) as north of Lake Lothing, the water is obtained from the Lound pumping station and resevoir, which gets its water from off the land surface and tends to be somewhat softer and nicer to drink. In the south of Lowestoft where I live, the water is supplied from Barsham (near Beccles) from a bore hole, and this water is harder and more bitter and has to be treated with more chlorine than the north. Nigel Quote Link to comment Share on other sites More sharing options...
Gordon Posted August 7, 2008 Share Posted August 7, 2008 Does anyone know the size of the tap fittings used at boatyards, both sizes I have found in diy shops and builders merchants are smaller and several do not believe a larger size exists Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted August 7, 2008 Share Posted August 7, 2008 I believe they are 1" BSP as opposed to domestic 3/4 BSP outside tap Gordon, here is a link to the hoselock variety http://www.twenga.co.uk/offer/73989462.html Edited to correct sizes 'cos not for the first time, I was wrong. Quote Link to comment Share on other sites More sharing options...
jimbo Posted August 7, 2008 Share Posted August 7, 2008 In our yard they are the 1" BSP . I use my own hose pipe to fill my tank up which came with an adaptor which is very handy Quote Link to comment Share on other sites More sharing options...
Mowjo Posted August 8, 2008 Share Posted August 8, 2008 Nigel! the hose I carry is 10 mtrs of 1/2" blue water hose, ( because it takes up less room than the 3/4") and a normal tap connector, I also carry a 1" bsp brass tap connector, if theres no hose I put my 1" thingy on the yards tap, then the normal tap connector fits on the end of that, I only really use it in B/Edge, as on our side in the new bit theres no hose, or if a yards hose looks a bit iffy I'll take theres off and use mine, Hoselock do a Threaded Tap Connector 1in BSP Part No 2158 then all you'll need is one of those quick fit hose fittings, I only use my way because it gives me a choice if a yards taps are a different size,, Most of the Marina taps I find are pretty safe as long as you run some water off first, It's places like Ludham and other public places I worry about, specialy when you see dogs peeing on the grass where there dragging the hose about, Quote Link to comment Share on other sites More sharing options...
