Antares_9 Posted October 16, 2007 Share Posted October 16, 2007 Unfortunately, the boating season is winding down in many parts of the country and it is time to start thinking about protecting your valuable recreational asset. Winterizing a boat reminds me of the old commercial that says "pay me now or pay me later." The time and effort you spend now will have a definite effect on your boat's performance, or lack of it, and certainly save you time, effort and money come spring. You should remember that your insurance policy may not cover damage done by lack of maintenance or neglect. Your first step in winterizing should be to make a checklist of all items that need to be accomplished. Check the owner's manual of your boat and motor(s) for manufacturer's recommendations on winterization. If you are a new boat owner, perhaps you should employ the assistance of a friend with experience in winterizing or hire a professional to do the job. The following is a general outline of areas which should be of concern to you, however, there are many resources on the Internet with more detailed and specific information. Inboard Engine(s) - You should run the engine(s) to warm it up and change the oil while it is warm. This tends to allow impurities to be drained away with the oil. You should also change the oil filter(s). Flush the engine(s) with fresh water. You should circulate antifreeze through the manifold by using a pickup hose from the waterpump to a bucket of antifreeze. Start the engine and allow the antifreeze to circulate until water starts to exit the exhaust. This process will vary slightly depending on whether you have a "Raw Water" cooling system or an "Enclosed Fresh Water" cooling system. While you're in the engine room you should also change the fluid in your transmission. Remove spark plugs and use "fogging oil" to spray into each cylinder. Wipe down the engine with an old towel sprayed with a little fogging oil or WD-40. Stern Drive(s) - You should thoroughly inspect the stern drive and remove any plant life or barnacles from the lower unit. Drain the gear case and check for excessive moisture in the oil. This could indicate leaking seals and should be repaired. Clean the lower unit with soap and water. If your stern drive has a rubber boot, check it for cracks or pinholes. Grease all fittings and check fluid levels in hydraulic steering or lift pumps. Check with your owner's manual for additional recommendations by the manufacturer. Outboard Engine(s) - Flush engine with fresh water using flush muffs or similar device attached to the raw water pickup. Let all water drain from the engine. Wash engine down with soap and water and rinse thoroughly. Disconnect fuel hose and run engine until it stops. It is important to follow a step by step process to make sure that all fuel is drained from the carburetor to prevent build-up of deposits from evaporated fuel. Use fogging oil in the cylinders to lubricate the cylinder walls and pistons. Apply water resistant grease to propeller shaft and threads. Change the gear oil in the lower unit. Lightly lubricate the exterior of the engine or polish with a good wax. Fuel - Fill your fuel tank(s) to avoid a build up of condensation over the winter months. Add a fuel stabilizer by following the instructions on the product. Change the fuel filter(s) and water separator(s). Bilges - Make sure the bilges are clean and dry. Use soap, hot water and a stiff brush to clean up any oil spills. Once the bilges are clean, spray with a moisture displacing lubricant and add a little antifreeze to prevent any water from freezing. Fresh Water System - Completely drain the fresh water tank and hot water heater. Isolate the hot water heater by disconnecting the in and out lines and connect them together. Pump a non-toxic antifreeze into the system and turn on all the taps including the shower and any wash-down areas until you see the antifreeze coming out. Also put non-toxic antifreeze in the water heater. Head - Pump out the holding tank . While pumping, add fresh water to the bowl and flush several times. Use Vanish crystals or whatever your owner's manual recommends that will not harm your system and let sit for a few minutes. Again add fresh water and pump out again. Add antifreeze and pump through hoses, holding tank, y-valve, macerator and discharge hose. Again, check your owners manual to make sure that an alcohol-based antifreeze won't damage your system. Interior - Once you have taken care of the system you should remove any valuables, electronics, string, life jackets, fire extinguishers, flares, fenders, etc. Over the winter these items can be cleaned, checked and replaced as necessary. Open all drawers and lockers and clean thoroughly. Turn cushions up on edge so that air is able to circulate around them or, better yet, take them home to a more climate controlled area. Open and clean the refrigerator and freezer. To keep your boat dry and mildew-free you might want to install a dehumidifier or use some of the commercially available odour and moisture absorber products. Out of Water Storage - pressure wash hull, clean growth off props and shafts, rudders, struts and trim tabs. Clean all seacocks and strainers. Open seacocks to allow any water to drain. Check the hull for blisters and if you find any that should be attended to you might want to open them to drain over the winter. While you're at it, why not give the hull a good wax job? It is probably best to take the batteries out of the boat and take them home and either put them on a trickle charger or charge them every 30-60 days. In Water Storage - Close all seacocks and check rudder shafts and stuffing boxes for leaks, tighten or repack as necessary. Check your battery to make sure it is fully charged, clean terminals, add water if necessary and make sure your charging system is working. Check bilge pumps to ensure they are working and that float switches properly activate the pumps and that they are not hindered by debris. Make sure either to check your boat periodically or have the marina check it and report to you. If in an area where the water you are parked in actually freezes, you should think about weather you really want to leave it in. By following some of the above suggestions, and other resources on the net, you should be in good shape for the winter. Do not, however, neglect to consult your owner's manuals for manufacture's recommendations on winterizing your boat and other systems. If you have not done a winterization job before or don't have an experienced friend to rely on seek out a professional to do the job for you Quote Link to comment Share on other sites More sharing options...
senator Posted October 16, 2007 Share Posted October 16, 2007 What a great post, Thanks David. Ian Quote Link to comment Share on other sites More sharing options...
Guest Posted November 14, 2009 Share Posted November 14, 2009 Worthy of a sticky, no? Quote Link to comment Share on other sites More sharing options...
pks1702 Posted November 14, 2009 Share Posted November 14, 2009 Worthy of a sticky, no? Ooh two Lake Sailors in a day I hope that Toby Jug still has some tokens left Quote Link to comment Share on other sites More sharing options...
Guest Posted November 15, 2009 Share Posted November 15, 2009 Except that I posted that two years ago Perry. For some reason David edited my post and amended the date. I'm sure my right to a lakesailor token has expired by now. Either that or someone logged into my account and posted because I was driving at the time! Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted November 15, 2009 Author Share Posted November 15, 2009 I gave it an auto bump Simon, that must have the effect of changing the date of the last post to the current date and time in order to bring it to the top. There are one or two pre decimal tokens left in the jug Perry, perhaps one of those would be appropriate. Quote Link to comment Share on other sites More sharing options...
pks1702 Posted November 15, 2009 Share Posted November 15, 2009 Oh no I couldn't possibly, it would be one taken under false pretences and that would not do Simon. Besides those pre decimal one will have passed their sell by date Quote Link to comment Share on other sites More sharing options...
