clive Posted October 6, 2015 Share Posted October 6, 2015 I have just purchased a computer on windows 8.1 and when I put a DVD in the built in player it goes onto the puta but only shows as video-RM and underneath it also lists video-TS but when I click on them to open they will not open and play I might add the video is one that I transferred from video to dvd using a separate machine designed for the job what I am wanting is to upload it so I can send it to you tube to be able to post it on a site locally to me .I am more used to xp where it did it automatically if any one can help could you explain it in simple terms due to being a silver surfer thanks all Clive. Quote Link to comment Share on other sites More sharing options...
deebee29 Posted October 6, 2015 Share Posted October 6, 2015 (edited) Hi Cliveit could be that you don't have a media player installed. I always install Vcl media player http://www.videolan.org/vlc/index.en_GB.html from this link. Its free, safe and will play just about anythingcyberlink that is often installed on pcs doesn't always play everything and can be temperamental at times Edited October 6, 2015 by deebee29 To add extra info Quote Link to comment Share on other sites More sharing options...
clive Posted October 6, 2015 Author Share Posted October 6, 2015 David the computer has Microsoft player on it but don't work on these DvD's as I have some that I had profecianaly transferred took in 8 mm film all about the broads. Quote Link to comment Share on other sites More sharing options...
clive Posted October 6, 2015 Author Share Posted October 6, 2015 tried vlc but no joy but I don't know how to get it onto vlc from the player I did once get it to play right through but for the life of me I don't know how I did it. Quote Link to comment Share on other sites More sharing options...
clive Posted October 6, 2015 Author Share Posted October 6, 2015 had to go into puta settings and do some changes I have now got it to play on VLC so how do I save it to be able to up load it to you tube is the question. Quote Link to comment Share on other sites More sharing options...
deebee29 Posted October 6, 2015 Share Posted October 6, 2015 Hi cliveit sounds like you need a video converter to turn it into an mp4 file. There are a lot around with differing degrees of success.I use a suite of programs called AVS4You which works very well for my needshttp://mobile.avs4you.com/index.aspxyou pay once and get a whole range of audio/video tools.the one you would need is the video converterhope this helps Quote Link to comment Share on other sites More sharing options...
grendel Posted October 6, 2015 Share Posted October 6, 2015 it does sound live the video is coded in a format windows eithe cannot play, or thinks the video is protected from being played, with VLC you either open the software and then ask it to open the file, or right click the file and then tell it to 'open with' and you should see vlc as an option.I use vlc for most things (video and music), you could just try uploading the file to youtube, this will automatically convert the file into the format it wants, or tell you it cant do it if it cant recognise the file type, at least then you will know.Grendel Quote Link to comment Share on other sites More sharing options...
Viking23 Posted October 7, 2015 Share Posted October 7, 2015 Does this mean we will get a chance to look at some old Broads Videos?If so... I'm sure there may still be some more help available to you.lol Quote Link to comment Share on other sites More sharing options...
