smitch6 Posted October 18, 2009 Share Posted October 18, 2009 i am in the process of restoring my boat and i made a dining area when it came to foam for the seats i rung round all the companies in the norfolk/suffolk area and was told that no-one stocked 4" foam how bizarre lol but they could get it in a week later anyway i scoured good old ebay and pm'd a chap on there with my phone number he called me back within the hour and gave me prices there and then it was VERY reasonably priced slightly cheaper than the cheapest quote i had locally delivery was fixed at £4.99 for each order so i ordered my foam next day delivery wow was good quality and cut exactly as i asked with a 2"taper for the rear seats lovely helpful chap so i ordered some more for the headlining and some glue that arrived the next day still £4.99 delivery but 2 parcels so even better value anyway this isn't my company but i do have his number if anyone needs foam etc give me a pm and i'll let you have it steve Quote Link to comment Share on other sites More sharing options...
jimbo Posted October 18, 2009 Share Posted October 18, 2009 Always good to know Steve Solving peoples boating problems is what we are here for! Quote Link to comment Share on other sites More sharing options...
jillR Posted October 18, 2009 Share Posted October 18, 2009 hi steve i cant remember the spec at the mo but you need to be sure its the right stuff the cheep stuff does not spring back into shape jill Quote Link to comment Share on other sites More sharing options...
Julz Posted October 19, 2009 Share Posted October 19, 2009 Hi Jill, i think the good upholstry foam is called 'Reflex' foam, although the very best for that kind of use these days is made up of layers, firm base, reflex core, and 'memory' foam topper for comfort, the latter being the most expensive of all three, although its the one which moulds to the shape of the occupant and does take some time to spring back into shape after usage Most modern foam mattresses are made this way, and are very comfortable, but for a solid block of foam, its the Reflex type that is best The cheap softer foams do tend to go out of shape quite quickly, and can 'Ground' you in the middle when used as a mattress, leaving a very compacted layer between a persons hips and the bed base, which is not nice and can cause aches and pains from a bad nights sleep Julz Quote Link to comment Share on other sites More sharing options...
smitch6 Posted December 19, 2009 Author Share Posted December 19, 2009 The foam is a very good quality a lot better than the last lot we bought it springs back every time only problem we have is we bought the 4" stuff but wish i'd have gone for thicker as it tends to hurt your tailbone after a while at least its only on the dining seats for now when i do the main seating area i will use thicker altho we sit on the dining all the time for now as its the only seating we have lol i shouldn't of ripped out all the other seating lol Quote Link to comment Share on other sites More sharing options...
Guest Posted December 26, 2009 Share Posted December 26, 2009 hiya I can source marine quality foam for those that might need it. One word of caution though, you should make sure the foam you buy is fire retardant to comply with current regulations, the cheap stuff is not always treated. If you pattern funny shapes I can get the foam cut to your pattern also. TIP.. Make sure that seat cushion foam is made 1/2 " bigger all over to make the cushions look filled. regards Richard Quote Link to comment Share on other sites More sharing options...
