TeamElla Posted September 29, 2016 Share Posted September 29, 2016 (edited) I thought that I would share this in case anyone else is suffering the same problem. It's an annoying fault with a simple remedy:- FAULT Compressor starts up o.k. when the thermostat calls for cooling (and runs fine for a good while), but a few minutes before the temperature drops low enough for the thermostat to switch off, the compressor stops. Then it starts again Then it stops Then it tries to start, fails and the fan runs for maybe 30 secs Then it gives a thump as though the compressor is going to start (but nothing happens except for the resultant vibration rattling anything loose in our adjacent cooker) Then it starts for 5 seconds and stops I think you've got the picture now, but this goes on about 10 to 15 times in various combinations of the above until the brief bursts of compressor activity lowers the temperature enough for the thermostat to switch off Observation: It's hard to sleep through all this, except during the rare occasions when the repeated surge actually takes out our fridge fuse REMEDY Change the thermostat - Job done -- No, it's nothing to do with low power supply voltage. It's high resistance across the thermostat switch contacts shortly before it's due to switch out. I have a theory that the thermostat starts to "slacken it's grip" when it's about to switch out and that's when the faulty contacts present a high resistance. EXTRA INFO The compressor can be run at different speeds, set by adjusting the value of a resistor that is connected in series with the thermostat contacts. The standard resistor is 1 Kohm, and it can be found on the little pcb that holds the green and red LED's. The purpose of this is to INCREASE the speed of the compressor rotation by REDUCING the current in the control circuit. Shorting the resistor out results in a compressor speed of 2000 RPM (which incidentally is incredibly quiet and would be good for night use), but the standard 1Kohm results in a compressor speed over 3000 RPM which is audible but not intrusive. If you are really fussy about fridge noise, you could short out the resistor and fit a quieter fan (and I doubt that you could hear it at all during the night). Edited September 29, 2016 by TeamElla technicality 1 Quote Link to comment Share on other sites More sharing options...
TeamElla Posted September 29, 2016 Author Share Posted September 29, 2016 Sorry - posted in wrong place. Can the mods please move where it belongs i.e. technical questions/answers maybe Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted September 29, 2016 Share Posted September 29, 2016 I too have a problem with my fridge. Some time ago I managed to blow a fuse and lost the electrics to the starboard side. I replaced the fuse but soon noticed that the fridge didn't work. I tested the power to the fridge, and it's there ok, but the unit is as dead as the proverbial. It does nothing at all. Any ideas? Sorry to hijack your thread Ella but you just reminded me to get off my jacksie and ask for advice! Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted September 29, 2016 Share Posted September 29, 2016 We have two problems with the fridge onboard 'B.A' 1) Girly crew members when onboard keep putting food in it leaving little room for beer 2) When all male crew onboard, somehow it keeps running out of beer Griff 4 Quote Link to comment Share on other sites More sharing options...
TeamElla Posted September 29, 2016 Author Share Posted September 29, 2016 MM, Is yours a Waeco fridge and is it totally dead (with not even a light illuminated as you open the door)? If so, you should first check whether the 12 volts is making it all the way to the Danfoss Electronic Unit on the back (Danfoss type no 101N0220 - probably). The top 2 contacts are the 12 volt input (but they may have piggy back connectors on them, doubling up each terminal). If power is there, there is a voltage regulator I/C on the outside of the electronic unit that could be faulty. Assuming that's o.k., you can bypass the thermostat by shorting terminals C and T together. This should cause the compressor to run continuously, otherwise either the electronic unit is faulty or another fault is preventing start up of the compressor. If another fault is responsible, the red fault light inside the fridge will flash a code that is repeated every 4 seconds, to identify the fault:- 1 flash = low supply voltage 2 flashes = fan drawing too much current (disconnect fan to see if fridge then runs) 3 flashes = Motor start error 4 flashes = Motor cannot maintain minimum speed (1850 RPM) 5 flashes = Electronic unit thermal cutout operating 3 to 5 you can't fix yourself. You can send the electronic unit to PenguinFrigo for testing (look them up on google) All the best, Steve Griff, Thought you'd be used to warm beer where you come from Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted September 30, 2016 Share Posted September 30, 2016 Hi Steve, My fridge is an Isotherm, I think. I'm sure it doesn't have any useful flashing lights. Even the light that used to come on when the door opened hasn't worked for some time, though I was quite happy with that as a power saving device! Are there any fridge engineers out there? Quote Link to comment Share on other sites More sharing options...
VetChugger Posted September 30, 2016 Share Posted September 30, 2016 I suspect "fridge engineering" must be something of a "black art"! I've tried in the past to find one without success. Advice from the manufacturers is only useful to a point. Like others have said, I bit the bullet and spent £600 for peace of mind and cold beer! 1 Quote Link to comment Share on other sites More sharing options...
TeamElla Posted October 1, 2016 Author Share Posted October 1, 2016 (edited) On 30/09/2016 at 8:45 AM, MauriceMynah said: Are there any fridge engineers out there? Hi MM, If your Isotherm is reasonably young, it too will have a Danfoss BD35F Compressor at it's heart (together with an associated 101N0210 or 101N0220 electronic controller), so the previous info will still be valid. The only difference between the two controllers is an added metal shield to help prevent electromagneitic interference on the 101N0220 version. Otherwise they're identical. I think that the Isothermfridgess don't have the fault LED fitted, but the terminals are there to attach your own for fault finding purposes (see the relevant drawing on the attached pdf). Assuming it's not an older model and assuming the electronic unit turns out to be faulty, you can send it to Penguin Frigo for testing. They can also offer advice on other problems. Also, Peachments in Brundall may be able to give advice. Relevant links:- www.penguinfrigo.co.uk http://files.danfoss.com/TechnicalInfo/Dila/06/bd35-50f_electronic_unit_01-2010_ei100b502.pdf Rgds, Steve Edited October 1, 2016 by TeamElla grammar corrected Quote Link to comment Share on other sites More sharing options...
TeamElla Posted October 1, 2016 Author Share Posted October 1, 2016 By the way, the fault identifying diode is item 6 in Figure 1:- http://files.danfoss.com/TechnicalInfo/Dila/06/bd35-50f_electronic_unit_01-2010_ei100b502.pdf Quote Link to comment Share on other sites More sharing options...
TeamElla Posted October 2, 2016 Author Share Posted October 2, 2016 ANY TAKERS? http://www.ebay.co.uk/itm/Waeco-CR50-fridge-/252564049694?hash=item3acdfd8f1e:g:USsAAOSwYIxX7oBR Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted October 2, 2016 Share Posted October 2, 2016 I'm hoping that getting mine repaired will be a less expensive option. Quote Link to comment Share on other sites More sharing options...
BroadScot Posted October 2, 2016 Share Posted October 2, 2016 Why are these small fridges sooooo expensive? Captive audience or pure greed! Or limited manufacture runs? Iain Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted October 2, 2016 Share Posted October 2, 2016 39 minutes ago, BroadScot said: Why are these small fridges sooooo expensive? Captive audience or pure greed! Or limited manufacture runs? Iain Hi Iain, I guess a bit of all three, mention boat or recreational vehicle and the zero's start adding to the bill. You have only got to look at 4 inch fans, mains versions from £12.00, 12 volt are from £50.00 with many being £100.00 for the more silent type. Regards Alan Quote Link to comment Share on other sites More sharing options...
BroadScot Posted October 2, 2016 Share Posted October 2, 2016 40 minutes ago, ranworthbreeze said: Hi Iain, I guess a bit of all three, mention boat or recreational vehicle and the zero's start adding to the bill. You have only got to look at 4 inch fans, mains versions from £12.00, 12 volt are from £50.00 with many being £100.00 for the more silent type. Regards Alan The fans I can understand, Alan, the motor windings are very technical. But fridges hmm, sorry, but that to me is a rip off !!! The dearest part of a fridge is the compressor unit, stats are cheap, I guess it boils down to what the customer is daft enough to pay!. Iain. Quote Link to comment Share on other sites More sharing options...
Gingerfrog Posted June 27, 2020 Share Posted June 27, 2020 Thank you team Ella, your tip on shorting T & C got my beer cold, although all lights and control are still dead as a dodo. My fridge died after what I suspect was being powered by a poor battery that kept dropping below low voltage cutout and flickering, even under charge Would replacing the voltage regulator I/C return power to control panel? Thanks again regardless, Spain in summer without cooling would have been lethal. Quote Link to comment Share on other sites More sharing options...
