Cheat's Roast
SteveO
One of the meals we do occasionally at home and which I shall be trying on the boat next season is called the cheat's roast.
Line a roasting tray or similar shallow container with foil to reduce washing up, chop up some spuds into roughly 1 inch chunks, add any root veg you have to hand (celeriac, parsnips, carrots and swede all give good results) drizzle with oil and mix to ensure that the spuds and veg are coated, then add some chicken pieces (legs and thighs with skin on and bone in are good), season and then chuck in the oven at gas mk 5 -6 for about an hour, turning the bits over half way through cooking. If you want to be fancy, you can add bits of bacon, slices of lemon and some mixed herbs before cooking.  Serve with green veg and some gravy made from Bisto chicken granules.
cheers
Steve
Barton Regatta feeding 8+ on WR.  Get a nice loin of pork (minus crackling), cover in foil with some water, put sliced garlic gloves into the skin and cook for a minimum of 3 hours removing foil about an hour before serving.  Pre made stuffing balls alongside, also pre made apple sauce at serving.  New potatoes and vegetables cooked in steamer  with ready made gravy inhanced with meat juices.  All on boat built for 3 people in 1933
(Crackling addtional supplied by guest)
  • 1 month later...
Lamb Chop bake
 In a shallow oven proof dish place thinly sliced onion, arrange tinned sliced carrots over the top with any other vegetables you fancy. Tinned butter beans works well also tinned chickpeas or sliced fresh courgette, butternut squash etc. thinly sliced,. Pour over tinned tomato soup so that veg is just covered, lay lamb chops on top of the whole lot season well and sprinkle liberally with dried mint, Bake in a hot oven until the chops are brown and crispy = about 45-50 minutes.  serve with jacket potatoes baked at the same time. This is a favourite of my family  on or off  the boat.
Carole
BOLOGNESE BURGERS  Finely chop and gently fry in a little oil or butter an onion until just softened. Put in a bowl together with some beef mince season well add a crumbled oxo  cube if liked, mix together,  form round palm sized patties  with a cube of mature cheddar cheese in the centre making sure the cheese is properly sealed, place patties in an  oven proof dish. Lay  a generous slice of cheese over the top of each one, pour over the whole lot a  tin/jar bolognese sauce. Bake in hot oven  for about 40 minutes.
Carole
Tonight it is gammon slices for me and Mike, Tan is trying to loose a few pounds so will be having a chicken breast cooked in water first then finished off in a frying pan with a sprinkled chicken oxo cub over the breast cut into slices.
No Yorkshire  pudding for Tan but more for Mike & myself. Already prepped vegetables, in the pans, pudding mix in the fridge now the time to put in the roasts and tomatoes in the oven.
my dinner tonight is 4 pork loin steaks diced, in the slow cooker with a couple of stock cubes, lentils green and red, and a stew pack of veg diced, all in a slow cooker earlier this morning, will be perfect when my daughter gets home and will feed two of us, tonight with mashed potato, and with the mash on top as a cottage pie tomorrow, 4 meals for a few quid
  • 3 months later...
This recipe is made mostly of stuff you are likely to have in the "larder" so if you're out somewhere away from shops Pubs etc., or the weather makes staying on board more attractive. it works a treat.
In an oven proof dish, layer sliced corned beef, sliced tinned potatoes, softened sliced onions, baked beans, grated cheese.Bake in a hot oven until cheese is golden and melted, -  about 45 minutes
You can use fresh potaoes but they need to be boiled until soft first.
Carole
Carole
And hopefully topped with lots of Parmesan cheese when served.
Yummy!
Carole
Bully beef is much under rated. I love it and that sounds a delicious recipe. Can't wait to try it.
