smitch6 Posted December 19, 2009 Share Posted December 19, 2009 hiya i use the red bottle's for our heating, hot water and cooking in the summer its fine we use about 19kg a month but in the winter we use 19kg a week trouble is the top of the bottle is freezing well all of it is actually but don't think the bootle freezing is a problem just the top where you turn the bottle on and off the reg and pipe is lagged with foam wrap and thermowrap so that should be ok i have also bought a cylinder jacket (the red one) wrapped that round the bottle and all over the top etc but to no avail once the temp dropped below 0c it froze again and luke warm water cooker dims when heating comes one so i know the gas it struggling we can't use the shower because the waters too cold any ideas how to stop this freezing ppl have said wrap towels etc round it but i have that jacket that should be batter than towels etc the red bottles should be good down to -15c i thought maybe they are duds lol any ideas folks please asap Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted December 19, 2009 Share Posted December 19, 2009 I would have thought that lagging it was the last thing you should do as it prevents the ambient air to internal temperature differential transferring heat even when quite cold outside. You can buy a heated jacket for the cyls which may help if on shore power. Another thing is the flow taken during high consumption in winter requires more heat to evaporate the gas at just the time less outside heat is available to do it. You may be able to solve or improve the situation by having a seperate cyl for the heating if there is room for one. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted December 19, 2009 Author Share Posted December 19, 2009 a separate line coming in isn't really an option unfortunately there is room for 2 bottles in my storage box on the back of the boat but everything is in the forward cabin so routing a new pipe would be impossible without ripping everything out Quote Link to comment Share on other sites More sharing options...
Guest Posted December 19, 2009 Share Posted December 19, 2009 Hi Steve, The bottle takes the heat from the air around it to turn the liquid in to gas. So you need to insulate the bottle in a housing and supply a small amount of heat ie 100 watt light bulb. If the liquid does not turn to gas it will be slow to pass through the regulator and pipework. Quick fix put an electric blanket over the bottle or pop your lead light in the storage box. ( not a low energy bulb though) Jonathan Quote Link to comment Share on other sites More sharing options...
smitch6 Posted December 19, 2009 Author Share Posted December 19, 2009 ok sounds good idea but........... the box i have my bottle's in is made of decking offcuts so there is gaps all over it like decking it designed to blend in rather than shove it in your face and the whole idea to change everything to gas was to try and reduce the leccy bill lol a 100w bulb will cost us lots and we are on a meter now as for the other reply having a seperat supply for water, heating etc impossible because i have a combi boiler which does heat and water and then a separate cooker so i can't have a dif line for water, heating etc its the boiler thats just being used normally and it trips each night so we wake to freezing temps while i have to push reset button Quote Link to comment Share on other sites More sharing options...
Guest Posted December 19, 2009 Share Posted December 19, 2009 Chuck an old duvet over the box and stick in a 60 watt bulb even at marina rates of 15pence per kwh will only cost about a penny an hour to run and you could always add a thermostatic plugin to turn it off above 2c. Jonathan Quote Link to comment Share on other sites More sharing options...
jimbo Posted December 19, 2009 Share Posted December 19, 2009 It could be your regulator is the source of the problem here as I've not known Propane bottles fail to gas at the temps we are having at the moment. Quote Link to comment Share on other sites More sharing options...
Boaters Posted December 19, 2009 Share Posted December 19, 2009 It may sound stupid,but it is Propane you have fitted ?? as I have a Butane bottle that is reddy-orange color .I have yet to fit my winter bottle,I think I am right in that Propane has a male end fitting and butane a female fitting with a nut I also think only Butane has the push on fitting.Hope I am being of some help,but that is how I recall it from caravanning days when we went out all winter . Quote Link to comment Share on other sites More sharing options...
Stranger Posted December 19, 2009 Share Posted December 19, 2009 hi steve the trouble with propane is that if theres any leak of gas it will cause freezing check the connections and that the pipe and crimp is in good condition the rubber pipe can become pourous as well this will also cause freezing Quote Link to comment Share on other sites More sharing options...
smitch6 Posted December 19, 2009 Author Share Posted December 19, 2009 sounds good but not 100% sure i am a bit dubious incase something catches fire esp with the gas bottles lol i know u're not meant to cover a light shade as the heat will catch it alight i suppose being outside it will never get that hot seems strange tho because the bottle is lagged so not sure i may be completely off line here and don't mean to sound doubtful or negative esp when u've taken the time to offer advice but the bottle is lagged well is that lagging holding the cold air in then? i thought it would help keep it warm its the top of the bottle thats freezing as i put a hair dryer on it for 5 mins and heated it and hey presto back to normal the rest of the bottle was still iced up that worked for a good few hours but temps gone down more again now so back to freezing so annoying Quote Link to comment Share on other sites More sharing options...
smitch6 Posted December 19, 2009 Author Share Posted December 19, 2009 yes defo propane butane doesn't come in 19kg and it has the male female fitting yes butane has the quick release one's the connections are all ok new rubber hose solids joins i always make sure the nuts etc are done up really tight when changing bottles i'm an ex builder so have always treated gas with loads of respect Quote Link to comment Share on other sites More sharing options...
jimbo Posted December 19, 2009 Share Posted December 19, 2009 Where abouts is the regulator situated? Quote Link to comment Share on other sites More sharing options...
smitch6 Posted December 19, 2009 Author Share Posted December 19, 2009 it screws into the bottle and the bottles are outside on the back of the boat Quote Link to comment Share on other sites More sharing options...
jimbo Posted December 19, 2009 Share Posted December 19, 2009 In that case I would seriously consider changing the regulator, as a first attempt at curing this problem. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted December 19, 2009 Author Share Posted December 19, 2009 i was then looking at the auto changeover type that way when 1 bottle freezes it will change it automatically they are only about £43 on ebay so hopefully will solve the problem Quote Link to comment Share on other sites More sharing options...
donnygeoff Posted December 19, 2009 Share Posted December 19, 2009 This might sound silly, and probably will. But what about the things that you keep your beer fermenting with. Are they any good, thay just draw a small current, but keep the home brew stuff at temp. Could these covers help. Don't shoot me down, just a thought. Quote Link to comment Share on other sites More sharing options...
jimbo Posted December 19, 2009 Share Posted December 19, 2009 The sort of temperatures we have been having of late would not freeze a Propane bottle. The trouble with the regulators is that they are sensative to freezing, as a lot of moisture can collect in them by the nature of the way they work, thus causing damage. A far better idea would be to insulate the regulator rather than the bottle to be honest. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted December 20, 2009 Author Share Posted December 20, 2009 i have wrapped thermowrap around the reg already Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted December 20, 2009 Share Posted December 20, 2009 but the bottle is lagged well is that lagging holding the cold air in then? i thought it would help keep it warm so annoying Lagging the bottle will prevent the ambient air temperature equalising the temperature and helping the liquid to become a gas. As the pressure in the bottle is reduced by taking off some gas for an appliance then some of the liquid turns to gas and in doing so takes heat from the surrounding air via the walls of the bottle. This is why one often sees frost on the outside of a bottle especially in high draw situations even when it’s well above freezing outside, the supporting physics for this is known as ideal gas law. Any insulation will hamper this process as of course insulating will keep cold as well as heat in. Even at lower temperatures the outside air is at a higher temperature than the cylinder walls above the liquefied gas. Bottom line is you need to provide heat for the liquid to become gas and you are hampering this by insulating the bottle, unless the insulated jacked has its own heat source that is. You don’t need to worry too much about the bottle freezing inside as propane has a freezing point of -190c and a boiling point (the point when it turns from liquid to gas) of -44c obviously like all liquids and gases these numers change when under pressure but it illustrates the low temperatures involved. Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted December 20, 2009 Share Posted December 20, 2009 Something else that I am reliably informed is often successful in stopping regulator freeze up is the fitting of a two stage regulator. Quote Link to comment Share on other sites More sharing options...
smitch6 Posted December 20, 2009 Author Share Posted December 20, 2009 thanks for that yes its defo the reg thats freezing not the bottle thats causing the problems we just got back and no gas i heated up the reg and hey presto it all works the reg is a very old one age unknown tho we have decided to get an auto change over one and insulate the new reg really well hopefully this will work Quote Link to comment Share on other sites More sharing options...
zacthedog Posted December 23, 2009 Share Posted December 23, 2009 It may have been said before but propane liquid turns to gas at -47 degrees so its not that as the liquid turns to gas it pulls heat from outside but if you have a too higher usage it can't keep up, you will need 2 bottles and a y adaptor wich allows the bottle with the greatest pressure to supply the gas the outside temp is not relevant for propane as with butane Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted December 23, 2009 Share Posted December 23, 2009 either that or nip out for a pee while cooking Quote Link to comment Share on other sites More sharing options...
Brian Posted December 23, 2009 Share Posted December 23, 2009 if you insulate the gas valve, it may freeze up quicker ? Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted December 23, 2009 Share Posted December 23, 2009 if you insulate the gas valve, it may freeze up quicker ? That's exactly waht I've been trying to get across throughout this thread, thanks Brian. Quote Link to comment Share on other sites More sharing options...
