Hockham Admiral Posted January 6, 2010 Share Posted January 6, 2010 Can anyone help, please? We need two burgee jack-staffs/jack-poles/flagpoles to fit our 1.25ins diameter front rails or two that will fit 45degs angled grab-handles aft which are 1ins dia. (The ones at Norfolk Marine will only go up to 1ins max dia and will only fit horizontal rails).They need to be 18ins or so in length. I spent over an hour yesterday on the web trying to source some to no avail. Quote Link to comment Share on other sites More sharing options...
Jim Posted January 6, 2010 Share Posted January 6, 2010 Hi John, I'm assuming you've already tried ASAP in Beccles and as another suggestion, try these people in Luton http://www.ecs-marine-equipment.co.uk/ A lot of the stuff they supply finds its was to places like Norfolk Marine but they may well have something that will fit the bill for you Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted January 6, 2010 Share Posted January 6, 2010 You should be able to mix and match from these John, will make up to most diameters and angles when used in combination, obviously you would need to get the staff seperately. http://www.makefast.com/sprayhood_section/tube_tube.asp Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted January 6, 2010 Author Share Posted January 6, 2010 Hi John, I'm assuming you've already tried ASAP in Beccles and as another suggestion, try these people in Luton http://www.ecs-marine-equipment.co.uk/ A lot of the stuff they supply finds its was to places like Norfolk Marine but they may well have something that will fit the bill for you Thanks, Jim and to make it easier to understand what I'm after here's a couple of pics of the bars in question: The front ones may even be 1.5ins dia. Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted January 6, 2010 Author Share Posted January 6, 2010 You should be able to mix and match from these John, will make up to most diameters and angles when used in combination, obviously you would need to get the staff separately. http://www.makefast.com/sprayhood_section/tube_tube.asp Yes, they look just the job, many thanks... err, now where do I get bits of s/s tube flattened at one end? Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted January 6, 2010 Share Posted January 6, 2010 Yes, they look just the job, many thanks... err, now where do I get bits of s/s tube flattened at one end? No need John http://www.makefast.com/sprayhood_section/internal_end_plugs.asp Quote Link to comment Share on other sites More sharing options...
Jim Posted January 6, 2010 Share Posted January 6, 2010 Problem solved then John by the looks of things! Looking at the site David posted the link to, I'd imagine anyone locally that makes canopies might be able to give you a pointer to a local supplier. At least you have decent sized rails. Our pulpit rail is quite small in diameter and finding the right clip to fix the NBN flag to the rail has led me all over as it seems very few can cope with smaller rails. Their only suggestion is to "fatten it up" with some hosepipe to increase the diameter Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted January 6, 2010 Author Share Posted January 6, 2010 [/quote] No need John http://www.makefast.com/sprayhood_section/internal_end_plugs.asp Quote Link to comment Share on other sites More sharing options...
