JohnK Posted October 24, 2017 Posted October 24, 2017 I’m thinking of getting something like this .... One double berthBasic cooking facilities (ok, I admit I just want to make coffee)Toilet. Small enough to moor next to a riverside property. I don’t know berth measurements. Preferably inboard diesel or electric. Ideally fits under PH bridge. I don’t know where to look or what to look for. Any advice gratefully received. Sent from my iPhone using Tapatalk Quote
CambridgeCabby Posted October 24, 2017 Posted October 24, 2017 If you want outside space A bounty 27 more internal space Hampton safari (25 ft) obviously without knowing budget etc is difficult to really know what to suggest but the two above start at about £5k for a rough bounty up to £25k for a tidy example what i would recommend is avoiding if possible a petrol boat as isn’t available waterside so means carrying fuel from a garage , and don’t jump in too quickly , Kate and I spent over a year till we found our ideal boat Quote
CambridgeCabby Posted October 24, 2017 Posted October 24, 2017 Waterside are selling a couple of their picnic boats which can be very easily converted to a double berth https://www.watersidemarinesales.co.uk/boats-for-sale/sheerline-pic-nic.html Quote
JohnK Posted October 24, 2017 Author Posted October 24, 2017 Thanks for that. Sounds like good advice. Not really sure on budget yet. I’m a contractor / consultant so if work comes in I’ll probably buy a boat that’s ready to go. If it doesn’t I’ll probably buy a project boat. Also don’t know what budget “needs” to be if that makes sense. Sent from my iPhone using Tapatalk Quote
dnks34 Posted October 24, 2017 Posted October 24, 2017 Deciding on your budget is usually the best place to start. Only thing is the boats I look at never fit my budget! Quote
JohnK Posted October 24, 2017 Author Posted October 24, 2017 Deciding on your budget is usually the best place to start. Only thing is the boats I look at never fit my budget! Noooo .... find what you want then justify it to your other half Sent from my iPhone using Tapatalk 2 Quote
CambridgeCabby Posted October 24, 2017 Posted October 24, 2017 The need (wish) to pass under Potter will restrict your choice greatly , and very very few will pass under at all times (even if the vendor says they do) . We decided that we would forgoe passage through Potter , and eventually our choice meant that Wroxham was also a no go so be prepared to modify your wish list Quote
WherryNice Posted October 24, 2017 Posted October 24, 2017 I reckon budget and mooring sizes would be the main initial considerations, then just get yaself round the brokerages to poke, prod n feel a few to see what you fancy, theres no substitute for actually being on board to get a proper sense of what they are like. NYA, NBS, and Waterside to name but three, all good places to nose around. Of course once you get a few in mind post on here for opinions and views etc Quote
WherryNice Posted October 24, 2017 Posted October 24, 2017 Jones Boatyard in St Ives Cambridge is worth a look too, tho if you buy from there you will need to transport by road n register etc Quote
Guest Posted October 24, 2017 Posted October 24, 2017 All I will say is if its the first boat you have bought then take someone who knows boats with you , it is a minefield out there and its very easy to miss something that that costs you dearly later . Moorings as going to be a major factor in what you buy , earlier models of the bounty 27 are the elysian , solid boats and a looked after mk2 is not that much cash , virtually all will have a diesel be it BMC or Perkins and don't be afraid of ex hire craft , yes they will have had repairs but so will private ones just remember a broken down hire boat earns nothing and therefore they were (are ) looked after , the end of the yr is time to buy deffinatly , tolls are looming as are big brown envelopes thanks to christmas and people want rid . I will admit to being a not biased regarding elysian boat I own one , it will for under potter with care and do all other bridge's when adapted into sneek under there mode . Quote
JohnK Posted October 24, 2017 Author Posted October 24, 2017 Thanks everyone. Some great tips there. Just a few points. It’s far from my first boat but will be my first cruiser. Mooring is sorted but space is limited. I might be able to move before the end of the year but I’m not sure yet. It will be kept near PH so if it won’t go under I’ll be halving where I can go with it. Sent from my iPhone using Tapatalk Quote
JennyMorgan Posted October 24, 2017 Posted October 24, 2017 The obvious answer to the ideal Broads boat that will go under all the bridges: Quote
JohnK Posted October 24, 2017 Author Posted October 24, 2017 The obvious answer to the ideal Broads boat that will go under all the bridges:I’m not an expert but I don’t think that would go under any of the bridges Sent from my iPhone using Tapatalk Quote
Guest Posted October 24, 2017 Posted October 24, 2017 2 hours ago, JohnK said: I’m not an expert but I don’t think that would go under any of the bridges Sent from my iPhone using Tapatalk Trust me it will they always have done , skills level is bordering magnificent but it wiil fit in the box as it were Quote
JohnK Posted October 24, 2017 Author Posted October 24, 2017 But it has that huge flagpole sticking up in the middle Saw one get lifted out at Goodchilds recently. Very impressive (boat and lift!)Sent from my iPhone using Tapatalk Quote
JennyMorgan Posted October 24, 2017 Posted October 24, 2017 Don't worry, John, like a Gt Yarmouth lady's drawers, quickly and easily lowered! 1 1 Quote
ZimbiIV Posted October 24, 2017 Posted October 24, 2017 1st work out what you want to spend, then forget that. 2nd work out what you must have, then forget that. 3rd work what you don't want, then forget that. 4tth work out what age you want, then forget that. 5th go out and fender kick everything. 6th be prepared to spend more than the boat cost, because you have discovered chandlery shops. You don't need that, BUT! I looked at this when we were thinking of changing, the one we bought was probably the first I disregarded looking on line! It suits us, probably paid too much (definitely). Thing to remember if it floats your boat, that's the one. paul 3 Quote
JohnK Posted October 25, 2017 Author Posted October 25, 2017 Using google earth I tried to measure the berth I’m hoping to get. It’s about 28 feet long by about 8 feet wide. Is that going to restrict my choice a lot?Sent from my iPhone using Tapatalk Quote
vanessan Posted October 25, 2017 Posted October 25, 2017 Sounds as if the beam might be restrictive. 1 Quote
ZimbiIV Posted October 25, 2017 Posted October 25, 2017 I think you need to look at a Viking 21, then they are narrow beamed boats. paul Quote
WherryNice Posted October 25, 2017 Posted October 25, 2017 A Colin Facey CF21 might do the job, 21'Long ×8'4" Beam(i think, will check later), little Yanmar 1GM10 inboard diesel on outdrive(well mine has anyway), tall enough to stand up in part yet goes through Potter pretty easily(think I had 6'3" on the gauge last time n it wasnt tight tight), galley and seperate heads(mine has a proper loo n tank but not sure if they all did) and two doublish berths or two single n one double. Think the same mouldings were used by others too. Hope thats of some assistance:) Quote
WherryNice Posted October 25, 2017 Posted October 25, 2017 Oh and if you want to see what one looks like, check my Avatar pic... Quote
ZimbiIV Posted October 25, 2017 Posted October 25, 2017 Ah a CF21 that was what our 1st boat was, we could happily spend a week on it. Seemed to run on fresh air never filled the tank during the season and wasn't much to fill it for the winter. paul Quote
JohnK Posted October 25, 2017 Author Posted October 25, 2017 Thanks for that. I’ll have a look at the Viking and CF boats. I think I’ll get away with slightly over 8’ as it will overhang the sides of the berth without a problem won’t it? Sent from my iPhone using Tapatalk Quote
WherryNice Posted October 25, 2017 Posted October 25, 2017 Which one was yours Paul? JohnK, I think it will depend on the shape of the hull, the CF21 for example is quite a bit narrower at the waterline than the gunwhale(if thats the correct term) I'd be happy to help with any measurements etc just ask Quote
