wayneakp Posted April 5, 2010 Share Posted April 5, 2010 Hi all I have a issue with my throttles or gearbox not engaging neutral properly. When mooring etc I put the lever in the neutral position but sometimes the boat carries on under power. Usually a little wiggle sorts it but sometines I have to go in the opposite direction first. This was made more apparent when I started the engine and on reving it to warm up the boat shot forward. I went to check the othyer helm and the levers were in neutral - good job I was still tied up. Has anyone else had this problem? Thanks in advance Wayne Quote Link to comment Share on other sites More sharing options...
Guest bluemood Posted May 20, 2010 Share Posted May 20, 2010 Hi sorted that thottle problem out yet i have volvo throttles 290 outdrives and initially had a problem sorting out neutral. The cables stretch and neutral is often in a slightly different position, in older boats, if no adjustments have been made. Quote Link to comment Share on other sites More sharing options...
wayneakp Posted May 20, 2010 Author Share Posted May 20, 2010 Hi sorted that thottle problem out yet i have volvo throttles 290 outdrives and initially had a problem sorting out neutral. The cables stretch and neutral is often in a slightly different position, in older boats, if no adjustments have been made. Hi - not yet - I seem to have developed a technique of wiggling the levers whenever I move out of gear I will get around to it though thanks Wayne Quote Link to comment Share on other sites More sharing options...
