Cockatoo Posted April 26, 2018 Posted April 26, 2018 In a couple of weeks time Debs and I are on Ranworth Breeze for a fortnight. The BCE will be joining us for the second week by which time we will be oop north, does anyone know where we can park his car in that area? (he has a blue badge if that helps) bearing in mind we can't get under Ludham Bridge so the Ant is a no go. He'll be with us when we return to Brundall so we can run him back to his car in ours. Quote
ranworthbreeze Posted April 26, 2018 Posted April 26, 2018 23 minutes ago, SteveDuk said: In a couple of weeks time Debs and I are on Ranworth Breeze for a fortnight. The BCE will be joining us for the second week by which time we will be oop north, does anyone know where we can park his car in that area? (he has a blue badge if that helps) bearing in mind we can't get under Ludham Bridge so the Ant is a no go. He'll be with us when we return to Brundall so we can run him back to his car in ours. Hi Steve, Here are some tide information from the Broads Authority tide tables where you should be able to get onto the Northern Rivers through Yarmouth. Fri 11th 06:57 1.58 18:40 1.64 00:27 0.22 12:36 0.58 Sat 12th 07:47 1.68 19:35 1.72 01:19 0.07 13:31 0.42 Sun 13th 08:33 1.77 20:24 1.80 02:07 -0.06 14:21 0.27 Mon 14th 09:16 1.84 21:12 1.89 02:54 -0.17 15:07 0.14 Tue 15th 09:58 1.88 21:59 1.95 03:40 -0.23 15:52 0.04 Quote
Wussername Posted April 26, 2018 Posted April 26, 2018 33 minutes ago, SteveDuk said: In a couple of weeks time Debs and I are on Ranworth Breeze for a fortnight. The BCE will be joining us for the second week by which time we will be oop north, does anyone know where we can park his car in that area? (he has a blue badge if that helps) bearing in mind we can't get under Ludham Bridge so the Ant is a no go. He'll be with us when we return to Brundall so we can run him back to his car in ours. The Malsters at Ranworth used to allow parking for a small fee and have used it myself only last year for three days. Worth a try. Andrew Quote
Cockatoo Posted April 26, 2018 Author Posted April 26, 2018 46 minutes ago, Wussername said: The Malsters at Ranworth used to allow parking for a small fee and have used it myself only last year for three days. Worth a try. Andrew Thanks Andrew that's definitely worth a try. 59 minutes ago, ranworthbreeze said: Hi Steve, Here are some tide information from the Broads Authority tide tables where you should be able to get onto the Northern Rivers through Yarmouth. Fri 11th 06:57 1.58 18:40 1.64 00:27 0.22 12:36 0.58 Sat 12th 07:47 1.68 19:35 1.72 01:19 0.07 13:31 0.42 Sun 13th 08:33 1.77 20:24 1.80 02:07 -0.06 14:21 0.27 Mon 14th 09:16 1.84 21:12 1.89 02:54 -0.17 15:07 0.14 Tue 15th 09:58 1.88 21:59 1.95 03:40 -0.23 15:52 0.04 Thanks Alan, we are planning to head north Monday or Tuesday. It's just a shame we'll have to head back south so early the weekend of the meet. Quote
Ray Posted April 26, 2018 Posted April 26, 2018 I believe you can buy long(ish) stay parking in Lathams large car park at Potter Heigham Quote
