Lastdraft Posted June 2, 2018 Posted June 2, 2018 I am looking to buy a couple of 12v Table Lamps, can’t find any anywhere, do they exist ? any help appreciated. Thanks Quote
Guest Posted June 2, 2018 Posted June 2, 2018 23 minutes ago, Lastdraft said: I am looking to buy a couple of 12v Table Lamps, can’t find any anywhere, do they exist ? any help appreciated. Thanks Maybe you could buy normal 240v ones and swap the bulbs to 12v? Quote
grendel Posted June 2, 2018 Posted June 2, 2018 https://www.ebay.co.uk/itm/2x-12V-LED-Spot-Reading-Light-Switch-Camper-Van-Caravan-VAN-Boat-Motorhome-Light-/123035879761 Quote
grendel Posted June 2, 2018 Posted June 2, 2018 you can get battery operated table lamps from camping suppliers. Quote
Lastdraft Posted June 2, 2018 Author Posted June 2, 2018 Thanks Grendel but was looking for more traditional lamps with lampshades and a warm light. Quote
grendel Posted June 2, 2018 Posted June 2, 2018 some of the led lamps from lidl run off a mains adapter, maybe these could be run direct off the battery. Quote
MauriceMynah Posted June 2, 2018 Posted June 2, 2018 Must it be 12 volt or will "Battery operated" do? Quote
Lastdraft Posted June 2, 2018 Author Posted June 2, 2018 I m sorry I’m not very technical but I have 12v sockets and just want to be able to plug them in away from mains power. Quote
grendel Posted June 2, 2018 Posted June 2, 2018 https://www.cotswoldoutdoor.com/p/vango-genie-rechargeable-100-lamp-D3714191.html?colour=180 these are usb rechargable, so a usb adaptor for the socket and they can be recharged. Quote
MauriceMynah Posted June 2, 2018 Posted June 2, 2018 Right, Try e-Bay and search Battery operated LED table lamp I think that might come up with the results you want, however, I rather like the idea of finding a 12v LED bulb (or lamp if you prefer) and putting it in a normal household table lamp then swapping the plug over to one for your boat's socket. Quote
Lastdraft Posted June 2, 2018 Author Posted June 2, 2018 MM didn’t know I could do that ! I agree thank you. This forum winds me up on occasions, but for advice and help , it’s first class. A mini problem I have been wrestling with for a week, solved in 10 minutes on the NBN. thanks all. 1 Quote
MauriceMynah Posted June 2, 2018 Posted June 2, 2018 I don't know if there is such a bulb(lamp) yet but I'm looking (because I might do the same thing :-) ) Quote
Guest Posted June 2, 2018 Posted June 2, 2018 52 minutes ago, Lastdraft said: I am looking to buy a couple of 12v Table Lamps, can’t find any anywhere, do they exist ? any help appreciated. Thanks Is there not a picture of such a thing on my last post? Quote
ranworthbreeze Posted June 2, 2018 Posted June 2, 2018 59 minutes ago, Lastdraft said: I am looking to buy a couple of 12v Table Lamps, can’t find any anywhere, do they exist ? any help appreciated. Thanks On Ranworth Breeze I fiited a standard 240 volt table lamp with a cigar lighter plug and bought 12 volt 20 watt Bus lamps for giving the boat that subdued lighting when watching the TV or we leave it on as a welcoming light from our return from the pub. They sell all the parts in Roy's DIY. Regards Alan Quote
Lastdraft Posted June 2, 2018 Author Posted June 2, 2018 As I said I’m not a technical person, but I like the idea of converting a normal 240v lamp. Didn’t know I could do that simply by changing the plug and bulb. I would never have thought of that. Glad I asked the question Quote
dnks34 Posted June 2, 2018 Posted June 2, 2018 I did something similar with a standard 50cm household gas cooker. Changed the oven cavity light to a 12v bulb and the internal spark generator to a 12v unit and hey presto youve got something the Chandlers will charge you a fortune for! Quote
MauriceMynah Posted June 2, 2018 Posted June 2, 2018 25 minutes ago, Lastdraft said: As I said I’m not a technical person, but I like the idea of converting a normal 240v lamp. Didn’t know I could do that simply by changing the plug and bulb. I would never have thought of that. Glad I asked the question Yes, the bulbs (lamps) are available on e-bay albeit from China for reasonable prices. Just thought I'd better mention, if you are buying a new table lamp to do this, make sure that the switch is a straight On/Off and not one that gives more than one brightness. Quote
Paws Posted June 2, 2018 Posted June 2, 2018 You can get 12volt bulbs from boulters marine they are also called bus bulbs just buy a normal lamp Quote
scaniaman Posted June 2, 2018 Posted June 2, 2018 12 volt/60 watt inspection lamp bulbs on ebad about £2 each should suit. Quote
scaniaman Posted June 2, 2018 Posted June 2, 2018 sorry MM they do an led version but my edit skills are not available on ebay, paul Quote
Bound2Please Posted June 3, 2018 Posted June 3, 2018 15 hours ago, MauriceMynah said: Yes, the bulbs (lamps) MM is sorta correct a bulb coming into bloom might look good for a few days. But a lamp as giving off a warm light I'm sure would be more what you are looking for. You plant bulbs and illuminate lamps. 1 Quote
MauriceMynah Posted June 3, 2018 Posted June 3, 2018 Not necessarily Charlie. this is like the arguments re Union Jack v Union Flag. If we accept Chambers dictionary and common usage a bulb is not only from a plant, it is also a round rubber sphere at the end of an antique motor horn as well as a lamp. Anyway, I reckon I'll be buying a table lamp or two, modifying each of them to take a 12v illumination source and a cigar lighter plug. Such a portable light on board makes so much sense. This has lead me to look at two other jobs to undertake. Upgrading the fuse box to take blade fuses and installing several cigar lighter sockets around the boat. Given my DIY skills, this should be fun !!! :-) 1 Quote
Guest Posted June 3, 2018 Posted June 3, 2018 5 hours ago, Bound2Please said: MM is sorta correct a bulb coming into bloom might look good for a few days. But a lamp as giving off a warm light I'm sure would be more what you are looking for. You plant bulbs and illuminate lamps. I just went into Roys and asked for a "table lamp illumination device", they said they hadn't got any and then asked "would these bulbs work ?" Quote
