wayneakp Posted May 24, 2010 Share Posted May 24, 2010 Hi I want to make some covers for an area in the lazarette. The inside of the hull is painted in a grey coating - it appears to be some sort of expoxy or water resistant paint - can anyone advise what I would need? thanks Wayne Quote Link to comment Share on other sites More sharing options...
Happy Jax 3 Posted May 24, 2010 Share Posted May 24, 2010 Hi Wayne See link below, from memory these locker paints are available in grey. http://www.boatpaint.co.uk/acatalog/Boa ... ts_50.html Quote Link to comment Share on other sites More sharing options...
wayneakp Posted May 24, 2010 Author Share Posted May 24, 2010 That look like the stuff - thanks Col rgds Wayne Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted May 24, 2010 Share Posted May 24, 2010 If it's on the "raw" side of the moulding it could be "flowcocte", just poly or epoxy resin with some micro baloons and pigment if you want to make your own. I think the real thing also has some stuff in it that makes it set without the air being excluded like gelcoat but if you use epoxy instead of poly then you shouldn't need that. Quote Link to comment Share on other sites More sharing options...
