Posted
I have been advised here that where you have a fast flowing tide, to moor up one needs to come in against the flow of water. Why?
I moor up helm side (Port) to the bank. I have to do this as I am normally single handed. I have been doing this for some years now and fail to understand why I should change. Please advise.
Posted
Because the tide acts as a break. It is possible to go against the tide with just enough power so that your boat is effectively stationary over the land. Allowing the flow of the tide to push on one side or other of your boat's bow will effectively move the boat sideways and into a mooring space, saves a fortune on bow thrusters. Going into a mooring with the tide under you means that you don't have the breaking effect that the good Lord provides for you.
Posted
You need forward motion through the water to get any steerage. If your coming in to moor and manage to slow the boat down enough but find you are still to far out from the quay heading, or the back is being caught by the current, or you are starting to be carried sideways, the only real way to correct this is to apply throttle to regain steerage. Off course any speed gained again is extremely hard to scrub off again if the tide is underneath you.
On the other hand when coming in against the tide you can easily scrub the speed off, have excellent steerage and manage to achieve everything at a much slower and importantly safer speed. At places like the Berney I have been able to stop in the water and use the rudder to take me sideways to the bank.
Like MM, when helming solo I prefer to moor port side, so on the South side am very aware of the tide times and where I intend to moor to ensure the tide flowing in the right direction for a port mooring. One of the reasons it is so annoying that Burgh Castle is closed. At any state of tide you could get a safe port side mooring at either Berney, or Burgh Castle. The direction of the tide dictated which one.
Posted
Also most props are far less efficient astern so you won't stop as well as you go forwards. Bow to the flow also provides a clean profile to the water, so in effect you may be at zero over the ground but are still able to manoeuvre as Peter describes.
I learn't a valuable lesson mooring stern to the flow at Coltishall when next morning I discovered they had been weed cutting up stream. It was building round my outboard leg and against the transom faster than I could clear it. If I had been bow to flow most would have passed under the hull just leaving a bit to clear by tilting the outboard.
Posted
Gentlemen please, you misunderstand my point. I have for some years now managed quite happily to moor up with the tide coming from astern.
I put the engine in reverse till I come to a halt (over ground) then "pull the stern in" by gentle use of the helm. It isn't easy, it takes practice and I can look a complete a**e if and when I get it wrong... but it is possible... I can do it... but I'm told I'm wrong to do it and I fail to understand why. (not why I'm wrong to do it but why I'm being TOLD I'm wrong to do it.)
I'm well aware that it's far easier to moor into the tide, but equally I'd point out that when running solo, it's safer to step off the boat and secure the stern line first (This applies to aft cockpit boats only... which mine is!)
Ok, now I know what is going to be said... "well if you are happy and competent to do this then carry on" but I'm sorry this wasn't always the case. The first time I attempted to do this I was neither happy nor competent, but I find like everything else in life, the more I do it the happier and more competent I get.
The novice boater (the intelligent ones who have worked out that a boat isn't like a car, and understand why ) may well work out how to tackle this, and may wish to do so. Would members advise them not to, or would those members offer advice as to the best way to go about it?
Posted
John, I would advise anyone, novice or otherwise, to come in against the tide or the wind, whichever has the greater effect on the boat. Got to say that I don't see a problem in doing so. Both bow and stern ropes ready and available in the cockpit, just step ashore and make fast, where is the difficulty in doing that? Using the tide against stem and rudder to sheer the boat in against the tide is simple and efficient, why make life less easy by reversing in? You haven't got to do it in any particular way, your choice!!
Posted
Just a thought, John, once moored, bow onto the tide, I can sheer the boat away from the shore and tight against the mooring ropes by putting the rudder over and steering away from the shore, the tide working on the rudder. Much more comfortable than bashing against the fenders!
Posted
Single handed I like a warp on a central cleat. Whatever the wind or flow is doing once the boat is secured in the centre you have control. Also makes setting springs of the bow and stern warps easier when short handed.
Posted
Agreed Chris, but sadly I don't have a central cleat
Peter, I have noticed that at Reedham for example sometimes the tide is going one way, but later it's running in the opposite direction so unless I turn the boat around when the tide changes your point isn't relevant.
When I step off my boat to tie up. I like to secure to the nearest post first. As Nyx is aft cockpit, that's the stern line secured first. The Bow line is going to be lied to a post at least 27 feet away. If I have come in stern to the tide, this is all pretty leisurely as the tide is keeping the bow to the bank. when mooring at Reedham on an incoming tide, then I'll be port side on but I have to tie up much faster before the bow swings out.
Posted
MM I did interpret your question as why do it, as opposed to why are you being told to do it differently. Ultimately as skipper you should do what you feel the safest and most comfortable for you. I guess those telling you to do it differently are offering advice based on the perceived technically correct way of doing things, not knowing it may not work for your particular situation. My answer was based upon the way I originally interpreted your question.
Re your observations of the tide at Reedham. One thing I have also noticed is that at the turn of the tide, the water may still appear to be flowing inwards, whilst the level of the water is actually starting to drop. The reverse is also true at the turn of the low water.
Posted
It’s the same in a lot of places, must be confusing for new hirers when they are given instructions re approaching and leaving moorings against the flow! :default_wacko:
Posted
I think its because until the incoming tide has reached the level of the outgoing tide it starts to hold the water back.  This causes a rise in water level until it has risen enough to push the water back up river, and vice versa.
Posted
Peter,  can you expand on this technique please,  wheel to port or starboard,  I tried it and the back end swung out. :default_dunce:
Posted
I've done this many times on the Thames when it's in flood, stronger flow than the tides at Yarmouth.  In everything from a 25ft Hampton to a 44ft Bounty, loads of different styles in-between and the odd narrow boat as well.
You only need small rudder movements and only for a short period before returning to straight ahead.  You need to keep the angle fairly shallow, too steep and the boat starts going backwards and you loose control.  When getting closer to the bank steer the opposite direction slightly to cancel the sideways movement.  You can always practise somewhere where the flow is strong but away from the bank, other boats etc to see how your boat handles.  All will do it but some are more responsive than others.
I've seen a Dutch barge go through a bridge backwards in a strong flow and maintain perfect control - I've never handled anything that big so the bridge may have ended up as a pile of rubble if I tried !!
Posted
I agree with Neil and would add that it is very important, when matching your speed to the tide, to keep your eyes straight up the river. Don't look too much at the bank - look straight ahead. This will tell you whether you are going sideways or not.
Posted
6 hours ago, MauriceMynah said:
Agreed Chris, but sadly I don't have a central cleat. But you could have, and very handy it would be too.
But it is relevant, either turn the boat with the tide and then go back to the land of nod  or cast off for an early start and go with the tide.
Posted
That's no problem, try it at potter and do us all a favour.:default_icon_twisted:
That bridge would make lovely hardcore!
  • Haha 3
