    Forum Shop
Sign in to follow this
Starbrite
Propeller Shaft Size
Can anyone tell me what size prop shaft is on a connoisseur 38 I want to put a rope cutter on any advice appreciated
The boat model alone may not help as it may have been re-engined at some time and had a stern gland changed at the same time.
You can't beat a vernier across the shaft, metric and imperial can be very close but not close enough to keep a rope cutter clamped.
A stripper should be matched to number of blades too (although mine are not).
It has a bmc 2.5 engine I wanted to order a rope cutter before I have it lifted to remove something I've got on the prop is the shaft the same size as the shaft that leaves the hydraulic drive?
Yes.
It will also have a standard length keyed taper, according to the shaft size, so as to fit standard propellors. I believe Connoisseur fitted shafts of 1.5" diameter to these boats.
In my experience, a cutter will not be of any benefit to you, on the Broads. You say you have something on the prop. It may just be a plastic shopping bag.
Yes.
Thanks for that my boat is in Yorkshire and I've picked up a bag with some clothes in it as I've got a piece of white plastic and part of a tee shirt off so far
×   Pasted as rich text.   Paste as plain text instead
  • NBN Mobile App
    Get it on Google Play
