baz1033 Posted June 6, 2010 Share Posted June 6, 2010 Hi we have just purchased a raymarine e120 and have wired the 12 volt in without a problem, but then I got the instructions out to wire in the new gps antenna into the seatalk wire when I found the the colour of the wires did not match each other or the instructions . Any advice or a recomendation of someone who i could get to wire it up would be great, we are based at wrc. thanks Barry Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 7, 2010 Share Posted June 7, 2010 The Raymarine kit usually allows two different methods of connection Barry, NMEA0183 and seatalk (similar to NMEA2000) what antenna are you using? Quote Link to comment Share on other sites More sharing options...
baz1033 Posted June 7, 2010 Author Share Posted June 7, 2010 Hi I think its somthing like a raymarine 125 gps antenna. i am at home at the moment so i am not entirely sure. sorry about this i will check when im down ina weeks time Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 7, 2010 Share Posted June 7, 2010 No Baz that’s enough to identify it, it will be a ray 125 differential receiver, I recommend that you use the seatalk connection then. You will need a seatalk junction box but don’t waste your cash on one from a dealer as they are available on fleabay for a lot less money as is the three contact plug and lead. Doing it that way will give you a seatalk junction into which you can tap any future raymarine stuff like autopilots and the like. The ray 125 has 5 cables red which is power in, yellow which is seatalk in and out, brown RTCM which in this case should be to ground, green which should be connected to the red and shield (silver) which should be grounded along with the brown RTCM. If you terminate all these in the junction box the colours in the seatalk lead will correspond. You will know if all is connected correctly if the LED on the 125 blinks in the correct sequence for seatalk (as per manual) Quote Link to comment Share on other sites More sharing options...
baz1033 Posted June 7, 2010 Author Share Posted June 7, 2010 Ok i will give that a go. I love the size of the screen and want to bet the radar for it as well so if you dont mind i may call on you again for advice on that. thanks very much for your help Barry Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 7, 2010 Share Posted June 7, 2010 Of course you can, somebody else may chip in too, the Radar is actually the easiest bit of all to connect up as it is a dedicated plug. Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 8, 2010 Share Posted June 8, 2010 I managed to find and scan the attached colour wiring diagram among my tech stuff , if you use that in conjunction with what I wrote above it should simplify things greatly. Quote Link to comment Share on other sites More sharing options...
baz1033 Posted June 8, 2010 Author Share Posted June 8, 2010 Thanks for that Where are you based boat wise if you dont mind me asking? Barry Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted June 8, 2010 Share Posted June 8, 2010 Shotley Barry, had 15 years broads based after coming in from an even longer time at sea but decided it was making us a bit lazy so back to briny based with occasional trips to the broads. Quote Link to comment Share on other sites More sharing options...
