Sealer
Owing to a misunderstanding between my wife and I (apparently I  "wasn't listening!) we left our boat with a leak over our grand daughters bed. We are going back today so I may need to sort this out whilst it is raining. It must be getting in around the handrails so I am hoping just to unscrew a little and get some sealer underneath. (Optomism). I remember reading of some very effective sealer that can be applied in the wet-can anyone advise please? Thanks.
To give it its full title:- Captain Tolleys Creeping Crack Cure  -  It's good stuff and does just what it says on the bottle.  We have used it far too many times tbh
https://www.amazon.co.uk/Captain-Tolleys-Creeping-Crack-sealer/dp/B003T6EJ9A/ref=sr_1_1?ie=UTF8&qid=1534058048&sr=8-1&keywords=captain+tolleys+creeping+crack+cure
Had to use it in anger on the window in a rented caravan when we were up on the Solway wildfowling and it did indeed effect a cure.
For permanent repair I like Dow Corning Geocel Marine Sealant. Will cure under water etc and it is available in small quantities. Unless doing a large job I find however well I seal the tube after use when I come to use it again it has set solid.
I do thank you guys for these and other such posts. I usually read about various products, remedies and suchlike and invariably find myself thinking how useful something might be. I bookmark anything I think may be of interest and, when the time is right, mention it to the boss. Sometimes he’s quite impressed and I can see him thinking ‘mmm, perhaps she does have her uses’!! So, thank you.
  • Thanks 2
When sealing stanchion bases or anything else thats screwed or bolted down you will get better results with a sealant thats compressible.  Basic silicone sealants tend to be squeezed out which doesnt leave much of a gasket between the mating surfaces.
I used to use Sikaflex but now I prefer to use CT1 in clear if its for exterior fittings as i think it cleans up leaving a neater finish.
Captain Tolleys is good to use around window frames where the silicone between the glass & frame leaks but as said it has to be run in dry or it will continue running through, not set and just end up making a mess. If used dry it can hold up for a long time if your lucky but many times the only reliable way to sort it out is with a proper window refurb/reseal. I have done this myself and found captain tolleys in the frame wet months after putting in so as good as it can be it can still be hit & miss.  Its certainly a worthwhile emergency item to have onboard.
Leaking windows espeacially if onto beds or bedding can be a big PITA and I think really spoil the onboard experience.
Hi John I use geocel 201 it's a frame sealer that's uv resistance it sets like a hard rubber if you place under a fitting don't tighten leave a little loose then when it has hardened of screw up tight, oh and don't forget a smear under the screw heads.John
If shares ever come up for B.A, you can count me out. :default_biggrin:
