Hair Straighteners
Guest itslewis
Guest itslewis
Hello,
just a quick topic.. anyone know if you can use simple GHD Hair Straighteners on the boat? Don't want to take them if they can't be used.
If they can't be used, are there nearby places where I could like communal toilets?
Thanks :grin:
Guest itslewis
Brilliant and thanks for the reply. We have 240v so I shall take them and hope for the best. I'm also taking a 12v converter 'thingy' to charge the iPod and Blackberry as I was told this would be the best from browsing through the forum!
Most hire boats with 240V inverters have a minimum of 1000W units. Just beware that a 600W set of hair straighteners will totally flatten the batteries in about 15 minutes! I would suggest only using them when the boat is going along.
Also, your yard will probably tell you you need to run your engines for at least 4 hours a day to charge the batteries. If using the inverter, this should be increased to 6 hours a day, or you will forever be calling out your yard to replace your flat batteries, which will spoil your holiday.
Aaah ... hair straighteners ... my pet subject! :grin:
If in doubt, you can purchase 12 volt hair straighteners now .... whilst not quite as good as those that you plug in to the mains, I am impressed with just how well they do actually work. I initially had some gas powered ones for boating ..... don't bother with those as they are worse than useless!! They don't get very hot and they just tend to rip your hair out! :o
My eagle eyed hubby then spotted some Vidal Sassoon 12 volt in-car straighteners - he's earned brownie points for life with that one! They are very small, but do get quite hot and have ceramic plates - the size means it takes a little longer than using the usual variety, but they do the job nicely. I don't know what the drain on batteries is, but presumably not that much. I will usually try to use them whilst underway but have used them for ten minutes in the morning before we set off and haven't flattened the batteries yet!
I have had a quick Google - there are quite a few makes of 12 volt straighteners now but someone is selling the same model I have on Ebay at the moment for £13 inc. postage:
http://cgi.ebay.co.uk/BNIB-VIDAL-SASSOON-CAR-CERAMIC-STRAIGHTENERS-/250650326871?cmd=ViewItem&pt=UK_Health_Beauty_Hair_Care_Hair_Straighteners_PP&hash=item3a5bec7757
Carol
Moderators - can I hide this thread from Annie as she was asking for just such an item the other day and of course I denied any such knowledge of their existence... my pocket is buckling at the seams!!! :naughty::naughty:
PM sent to Annie to let her know what a tight wad you are :lol:
Guest DAYTONA-BILL
Like the idea of the 12v straighteners, pity i did`nt know about them 3 weeks ago then SWMBO would have been happy on Tower Bridge. Never mind, i`l surprise her with a set for next year (might even try and talk her into another trip in September if finances will allow).
Conspiratorial... I think I'm going to have teurettes now.... :naughty::naughty: I mean, if she had asked me for something more useful like a polishing machine or a new mini-vacuum for the boat I may have thought differently..... two guns
However, she has just seen this and is now furiously looking up 12v running machines......
My wife and daughters took some GHD's last year along with another make, our boat was only 2 year old and could run up to 2000 watts using the invertor and they would not work for some reason yet the powerful hair drier did work which was 1600 watts.
  • 1 year later...
Guest DAYTONA-BILL
We DID buy a pair of 12v hairstraighteners from "Towsure" (the caravan and camping company) for our trip last year, and they DO work, albeit not quite as well as 240v ones, but they are very effective. I`d recommend them, as you can plug them into the cigar lighter socket, which most boats have. Even though we now have a 240v hook-up socket (thanks John cheers ), we will still take them along for when we`re moored up somewher where there are`nt any hook-up points.
Some GHD straighteners will work on an inverter and some won't. I have been experimenting recently ahead of an upcoming trip to the Broads. I'm an electrical engineer.
I've found the older GHD Mk3 (or Mk3.1) models will not work on an inverter (unless it is a very expensive one). This is likely because most inverters do not produce a true sine wave as found on the mains.
GHD MKIV or MKV (mark 4 or 5) models will (can) work, or at least they did on the two leisure inverters that I have tried. These models will also work properly on different mains voltage (i.e. in the USA and UK).
The inverter will need to be rated at least 300W (preferably more) and have a GOOD connection to the 12V battery. It's best to have the engine running so the alternator provides power. A connection via a cigar lighter socket is unlikely to be good enough and the fuse may blow. The DC current is around 30A, particularly during the warm up phase.
There are a number of variables involved here so there is no assurance that any particular combination of inverter, boat, wiring or straightener will work.
Guest DAYTONA-BILL
That`s exactly what we found. When we plugged them in, they blew the fuse immediately, so we changed it, and did the same again, so we did`nt use the inverter at all. The 12v ones are pretty good, and worked well. A lot more effective for 12v items than a 12v hair dryer, in comparison to their 240v versions. I forgot to say, the inverter was of the type that plugs in to a cigar lighter socket too. Probably best suited for charging up phone and camera batteries only.
