Sazzajn Posted September 7, 2018 Share Posted September 7, 2018 Hi fellow boaters.....looking for some advice....our bilge pump has all of a sudden started to overrun slightly ie once the water has finished being pumped out, rather than stopping (as it used to do), it now carry’s on for a little longer....why / what would cause this to happen??Thanks in advance for any insightful help. Sent from my iPhone using Norfolk Broads Network Quote Link to comment Share on other sites More sharing options...
dnks34 Posted September 7, 2018 Share Posted September 7, 2018 My guess would be float switch sticking slightly. Quote Link to comment Share on other sites More sharing options...
JanetAnne Posted September 7, 2018 Share Posted September 7, 2018 Slightly sticking or maybe wear in the pivot. Another possibility is something catching the float as it returns or maybe debris in the way. If its one of those awful built in automatic items then you may not be able to get to the float to clean / service it. 1 Quote Link to comment Share on other sites More sharing options...
Chelsea14Ian Posted September 7, 2018 Share Posted September 7, 2018 I think maybe get a man in to look at it Quote Link to comment Share on other sites More sharing options...
Maxwellian Posted September 7, 2018 Share Posted September 7, 2018 Try warm soapy water over it. Quote Link to comment Share on other sites More sharing options...
Maxwellian Posted September 7, 2018 Share Posted September 7, 2018 Eco friendly of course Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted September 7, 2018 Share Posted September 7, 2018 Sticking float switch. Quote Link to comment Share on other sites More sharing options...
DaveRolaves Posted September 7, 2018 Share Posted September 7, 2018 oil in the bilge water is a possible cause. Try cleaning the pump and also clean the bilges out. Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted September 8, 2018 Share Posted September 8, 2018 Our bilge pumps are fitted in stainless trays, it is just a case of removing the jubilee clip and pulling apart the bullet connections and the unit can be lifted out for inspection/repair. On our last allocation I had to replace one of the bullet connections because it was corroded. My guess it like the other comets is that you may need a new float switch. Regards Alan Quote Link to comment Share on other sites More sharing options...
Sazzajn Posted September 9, 2018 Author Share Posted September 9, 2018 Thank you all for the help and advice...much appreciated as always!Sent from my iPhone using Norfolk Broads Network Quote Link to comment Share on other sites More sharing options...
