Posted
10 hours ago, smitch6 said:
I'm after a windlass ( i think thats what they're called) to winch my mudweight up
if anyone has one pls give me a shout
I nave one :default_eusa_naughty:
Posted
Hello smitch6,
Is it the windlass handle you require or the complete windlass and handle?
If it is just the handle then Boulters stock them.
Posted
Hi Mitch Have you thought about how you will fit it on the bows, do you have access for a reinforcement plate and access to the bolts/nuts underneath the front bows, many boats have sealed fore decks. will you leave it dangerling or will you lift it on the deck, this will be difficult to do. sorry to maybe dishearten you but winches can be expensive to buy and fit ,unless you can do DIY, and do need thinking ahead to remove disappointment. If you find it hard to break the initial suction, drive the boat forward with the engine to break the weight out, then pull it up onto the deck.  Best of luck. John
