    Forum Shop
Sign in to follow this
ranworthbreeze
Adp Notice 6 & 7 Of 2019 Re Bascule Bridge Temporary Closure & Bathymetric Survey
Dear All
Please find attached ABP Notice to Mariners No 06 of 2019 regarding Bascule Bridge temporary marine closure & No 07 of 2019 regarding Lowestoft Harbour bathymetric survey
Kind Regards
Laura Milner
Administrative Officer Operations
Broads Authority
Tel: 01603 756035
NOTICE TO MARINERS
LOWESTOFT HARBOUR – BATHYMETRIC SURVEY
Mariners and Port Users are advised that pre dredge bathymetric survey operations are
scheduled for Lowestoft Inner and Outer Harbour Areas, also Lowestoft Approaches as
follows:-
27th March 2019 – full Inner and Outer Harbour area, and Lowestoft Approach Channel
survey by vessel ‘Wyke’. Vessel will be monitoring VHF Ch14 throughout the survey
activities.
All other vessel movements will be monitored and co-ordinated via Lowestoft Port
Control. Vessels will be updated with survey activities and location accordingly.
Vessels are requested to afford the survey vessel a wide berth, and pass at slow speed
to minimise vessel wash.
Please contact Lowestoft Port Control, VHF Ch14, or Tel. 01502 572286, if further
information is required.
Harbour Master
26th March 2019
NOTICE TO MARINERS
LOWESTOFT BASCULE BRIDGE - TEMPORARY CLOSURE
AND RESTRICTIONS TO MARINE TRAFFIC
Mariners and Port Users are advised that the Bascule Bridge will be
undergoing routine maintenance for the period below:-
Thursday 4th April 2019 at 2000hrs until Friday 5th April 2019 at
0600hrs
 During this period there will be no routine small boat openings.
 Commercial vessel openings will be considered with a minimum of
12hrs notice and subject to the works schedule. Vessels restricted to
HW period port entry/departure will be prioritised.
 Small vessels and Leisure craft may be able to utilise a commercial
vessel opening should one be scheduled during the restriction
period, subject to the required transit being in the same direction,
and only with consent of the Harbour Master via Port Control.
Agents, Owners and Vessel masters are advised to bear this closure in
mind when planning vessel movements in or out of the Port of Lowestoft.
For further information please contact Lowestoft Port Control, (VHF Ch.14,
Tel. 01502 572286).
Harbour Master
26th March 2019
  • NBN Mobile App
    Get it on Google Play
