ExSurveyor Posted November 20, 2019 Share Posted November 20, 2019 4 hours ago, BuffaloBill said: Maybe Amps even........... (Just as you thought I'de gone quiet..........) I believe anything you lot say although even i recognized 1.5watts wasn't a lot Quote Link to comment Share on other sites More sharing options...
annv Posted November 21, 2019 Share Posted November 21, 2019 Hi Floyd The 35 amp charger is only big enough to maintain two 100/110 amp batteries you need a larger enough size charger to be able to charge at a high enough amperage to keep in tip top condition if batteries aren't charged at their max amps periodically they won't last as long as they could, if you have more than two batteries you need a higher output charger to be able to deep charge them to get the maximum life from them. John Quote Link to comment Share on other sites More sharing options...
floydraser Posted November 22, 2019 Author Share Posted November 22, 2019 On 21/11/2019 at 09:22, annv said: Hi Floyd The 35 amp charger is only big enough to maintain two 100/110 amp batteries you need a larger enough size charger to be able to charge at a high enough amperage to keep in tip top condition if batteries aren't charged at their max amps periodically they won't last as long as they could, if you have more than two batteries you need a higher output charger to be able to deep charge them to get the maximum life from them. John Thanks for that John. I won't chuck the present chargers away too quickly then! 1 Quote Link to comment Share on other sites More sharing options...
