wayneakp Posted December 5, 2010 Share Posted December 5, 2010 Hiya Just wondering about Eberspachers..as you do..oh...just me then. Anyway - What are the pros and cons of the Air type vs the water type. To my thinking the wet type with a few blown matix around the boat has to give a better heat transfer and more even heat than the air type? Would be interested in peoples experiances. rgds Wayne Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted December 5, 2010 Share Posted December 5, 2010 On a big boat I would certainly agree that a water type is the way to go, easier routing of hoses instead of bloody big trunking, also makes hot water, can be arranged to pre heat the engines if desired. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 5, 2010 Share Posted December 5, 2010 advantages of the latter idea: if you have large diesel engines under the saloon floor and they are preheated through an eberspacher or etc... once you get them well warmed you start to turn them into radiators... the resulting underfloor heating is quite pleasant in the evenings... Quote Link to comment Share on other sites More sharing options...
Guest Posted December 6, 2010 Share Posted December 6, 2010 Wet system = heated towel rail in heads. Luxury Quote Link to comment Share on other sites More sharing options...
senator Posted December 6, 2010 Share Posted December 6, 2010 Was going to ask whether there was a problem with water making its way forward against the inertia of the boat but then remembered there wouldn't be any Quote Link to comment Share on other sites More sharing options...
wayneakp Posted December 6, 2010 Author Share Posted December 6, 2010 Was going to ask whether there was a problem with water making its way forward against the inertia of the boat but then remembered there wouldn't be any But by the same token the water in the system will remain on both sides of the boat, not just one side or the other on a frequently changing basis Quote Link to comment Share on other sites More sharing options...
Guest Posted December 6, 2010 Share Posted December 6, 2010 Surly hypothetical Ian as both systems run on diesel not petrol Quote Link to comment Share on other sites More sharing options...
