Morse Control System
the Volvo system use ds units for gear, but a 'lost motion' link with two throttle cables on each engine..........
' lost motion'  I think is possibly something to do with activity or lack of it between control lever and gearbox ?
Hi You may find it refers to the slotted control on duel control there are two slotted bars when one is pulled the motion is lost in the parallel one as the pine slides up the slot and is lost it is then returned by a spring you can then pull the other one with out affecting the parole one . John
