annv Posted July 15, 2020 Share Posted July 15, 2020 And rather than have a anode on the prop shaft and run the risk of vibration through imbalance you should earth it via a slip ring unless it doesn't have a insulated anti vibration gear box output coupling or if so has a earth strap between shaft and gear box which then needs to be connected to the anode. John 1 Quote Link to comment Share on other sites More sharing options...
Cheesey69 Posted July 15, 2020 Share Posted July 15, 2020 Had my sail boat on the Medway in a marina that dried out between tides. The boat hulls made a sort of lake in the mud in which our boats sat. it seem a boat nearby or even the pontoons earth return was faulty or corroded but my prop and anodes just vanished in 6 months. So I boughta galvanic isolator that went in line with shore power cable and never had a problem again 2 Quote Link to comment Share on other sites More sharing options...
Vaughan Posted July 15, 2020 Share Posted July 15, 2020 46 minutes ago, Cheesey69 said: So I boughta galvanic isolator that went in line with shore power cable and never had a problem again That is always a good option! 1 Quote Link to comment Share on other sites More sharing options...
NeilB Posted July 15, 2020 Share Posted July 15, 2020 1 hour ago, Cheesey69 said: Had my sail boat on the Medway in a marina that dried out between tides. The boat hulls made a sort of lake in the mud in which our boats sat. it seem a boat nearby or even the pontoons earth return was faulty or corroded but my prop and anodes just vanished in 6 months. So I boughta galvanic isolator that went in line with shore power cable and never had a problem again I've heard of case's where they have disappeared in 6 weeks due to faulty wiring ! 1 Quote Link to comment Share on other sites More sharing options...
Cheesey69 Posted July 15, 2020 Share Posted July 15, 2020 As a side note, I also switchEd off the 12volts at the main switch so nothing was drawing power (had no bilge pump, manual) and connected a multi meter to the terminals. Found a high reading in micro volts. Turns out the alternator was allowing power to back flow which would energise the engine at rest and to those anodes. New alternator stopped that Quote Link to comment Share on other sites More sharing options...
