Guest Posted August 14, 2020 Share Posted August 14, 2020 Need a new 4 burner LPG hob for the boat (500mm x 400mm) can anyone recommen a source...ta. Quote Link to comment Share on other sites More sharing options...
marshman Posted August 14, 2020 Share Posted August 14, 2020 Currys? B & Q? But you may need to change the jets! 1 Quote Link to comment Share on other sites More sharing options...
Vaughan Posted August 14, 2020 Share Posted August 14, 2020 And make sure it has flame failure devices on each burner, to pass the BSS. Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted August 14, 2020 Share Posted August 14, 2020 Thinking 500 x 400mm might be a difficult size to find that said I spent hours trawling through sites for Motor Homes, Camping & Leisure, Boat chandlers and so on after trying the mainstream Currys etc. Found mine on either fleabay or Amazon in the end but had to change to Propane gas. Quote Link to comment Share on other sites More sharing options...
marshman Posted August 14, 2020 Share Posted August 14, 2020 All hobs for domestic houses now have to have FFD's as standard as it is a requirement of landlord/tenants etc Quote Link to comment Share on other sites More sharing options...
Poppy Posted August 14, 2020 Share Posted August 14, 2020 https://www.midlandchandlers.co.uk/products/thetford-4-burner-lpg-hob-unit-stainless-n32-ss Quote Link to comment Share on other sites More sharing options...
CambridgeCabby Posted August 14, 2020 Share Posted August 14, 2020 If you need someone to install it , we used John Spruce 07768072004 , who was recommended to us by Alan May when he did our BSS , we found him excellent and most reasonably priced 1 Quote Link to comment Share on other sites More sharing options...
scaniaman Posted August 14, 2020 Share Posted August 14, 2020 If your looking in the second hand market, The caravan centre at Blaenavon have loads of used parts and may be able to help.The Caravan and motorhome club have a list of caravan breakers in a Pdf. Also, O`learys and Magnum caravan spares have loads of new spare parts which come from the caravan and motorhome manufacturers end of production lines. Always heed the safety warnings that have been mentioned above. Hope this helps. Paul Quote Link to comment Share on other sites More sharing options...
Vaughan Posted August 14, 2020 Share Posted August 14, 2020 4 hours ago, CambridgeCabby said: If you need someone to install it , we used John Spruce 07768072004 , who was recommended to us by Alan May when he did our BSS , we found him excellent and most reasonably priced John is a good friend of mine, from when he was the chief engineer at Crown Cruisers. I would recommend him without hesitation. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 14, 2020 Share Posted August 14, 2020 Thanks folks, going to with Poppy's suggestion and will order tonight, also already know John Spruce from a previous job he did for us, in fact I spoke to him this morning about fitting said hob. Once again thanks.. Quote Link to comment Share on other sites More sharing options...
