Soundings Posted February 14, 2011 Share Posted February 14, 2011 Just moved the boat from Broadsedge to Richos. Had to de-winterise so at least know the boat wintered well (so far). Having leccy hook-up at the new mooring I thought that rather than winterising again I would put a greenhouse heater in the engine bay of my Aquafibre 33. Most people seem to use a tube heater and if I use one of these what size would be ok - I have read somewhere that 80 watts is sufficient? That said, I do have a fan assisted greenhouse heater available and wonder if this would do the job? Advice appreciated. Quote Link to comment Share on other sites More sharing options...
diesel falcon Posted February 14, 2011 Share Posted February 14, 2011 hi, wouldn,t put a 240v fan in the engine bay too complicated ,just put two small tube heaters either side of the engine and put them on a thermostat,better if they are independant ...more reliable Quote Link to comment Share on other sites More sharing options...
Soundings Posted February 14, 2011 Author Share Posted February 14, 2011 Thanks but what is the perceived problem? The boat is wired for shore power so what would the difference be between the two heat sources (tube/fan). Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted February 14, 2011 Share Posted February 14, 2011 I would stick with what you already do, 240v can fail, a drain down or anti freeze is less likely to do so. No harm in both though. Quote Link to comment Share on other sites More sharing options...
diesel falcon Posted February 14, 2011 Share Posted February 14, 2011 dotting the t,s and i,s really but if one stat or heater failed you,d have a back up,coarse if shore power failed you,ve had it anyway! but for peace of mind drain it,especially if you don,t use the boat often in winter Quote Link to comment Share on other sites More sharing options...
Soundings Posted February 14, 2011 Author Share Posted February 14, 2011 I am happy to take the chance on shore power staying up as there seems to be a high degree of reliability at Richos. Also as we move towards spring the really bad cold nights "should" be a thing of the past (famous last words those ). Also I only live 10 mins from the boat. If it were November I would cetainly do a full antifreeze job. So against all that - would a greenhousee fan heater serve as well as a tube heater? Many thanks Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted February 14, 2011 Share Posted February 14, 2011 I have to say I'm not keen on non encapsulated heating elements in engine spaces and if the fan assisted heater is of that type then I would not like it in there. I'm certain it would do the job though, just that it would worry me a bit, unless of course it was a petrol engine in which case it would worry me a lot. Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted February 14, 2011 Share Posted February 14, 2011 Totally agree with David. At this time of the year I won't even leave the fan-heater on in the cabin if we leave the boat for a jar or two........ Quote Link to comment Share on other sites More sharing options...
diesel falcon Posted February 14, 2011 Share Posted February 14, 2011 That would be a very cold boat you have there then Quote Link to comment Share on other sites More sharing options...
Guest Posted February 14, 2011 Share Posted February 14, 2011 I agree with Antaries, it's much safer to use encapsulated tube heaters. My boat has got a petrol outdrive with raw water cooling, so I have to take a lot more care than most people. I understand that the recent cold snap has resulted in a great many cracked blocks in raw water cooled boats, even where people have relied on heating, where it has either tripped out or been of insufficient wattage for these extremes. I've had an 85 watt tube heater in my engine bay for some time, but the max/min showed that over Christmas it still fell to -5c , so it wasn't sufficient this Winter. I've therefore added a second one, controlled by the same thermostat, so I now have 170 watts. As my boat is petrol, I have an electronic thermostat in the cabin, with a remote sensor in the engine bay, to remove the chance of any sparks. I've also fitted brass drain cocks, so that I can also drain down the block and manifolds very quickly and easily. (and they were completely drained down during that last spell !) Quote Link to comment Share on other sites More sharing options...
Guest Posted February 15, 2011 Share Posted February 15, 2011 I have two tube heaters on dedicated frost stats set at 5c and I also close 75% of the engine air vents. I have an alarm that texts me if the power should fail and I can turn on the eberspacher remotely. Should I fail to do this the eberspacher will turn on at 2c regardless. Well you cant be to careful Jonathan Quote Link to comment Share on other sites More sharing options...
Soundings Posted February 15, 2011 Author Share Posted February 15, 2011 Tube heaters and thermostat it is then. Next question, where is the best place to buy the kit? I am in the Potter Heigham are of Norfolk. Thanks Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted February 15, 2011 Share Posted February 15, 2011 I imagine ASAP supplies would have best value, though any electrical wholesaler or retailer should have them. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 15, 2011 Share Posted February 15, 2011 Tube heaters and thermostat it is then. Next question, where is the best place to buy the kit? I am in the Potter Heigham are of Norfolk. Thanks I scoured the Planet for the cheapest prices ( ), and bought them via ebay for about £25, then found I could have got them from Wroxham at almost the same price ! http://www.norfolkmarine.co.uk/shop-onl ... -4597.html The thermostat was somewhat trickier for me though, being a petrol boat I had to have a remote sensor elctronic stat, and that I could only find on the Internet for a reasonable price. Quote Link to comment Share on other sites More sharing options...
Hockham Admiral Posted February 15, 2011 Share Posted February 15, 2011 Tube heaters and thermostat it is then. Next question, where is the best place to buy the kit? I am in the Potter Heigham are of Norfolk. Thanks I bought mine (both heaters and thermostat) from B&Q. Good prices and not too far from you! Quote Link to comment Share on other sites More sharing options...
Soundings Posted February 15, 2011 Author Share Posted February 15, 2011 Heater and thermostat duly obtained - from Norfolk Marine (B&Q did not have any in stock). Big question how do I wire the thermostat in? I have looked at the diagram but it seems odd - it is a shunt arrangement with Live, Neutral, Earth and Load connections. Load seems to be a continuation of Neutral but when the thermostat switches on it becomes Live. Presumably Load goes to the heater. I have done a lot of thio stuff so what am I missing Diagram attachedDiagram043.pdf Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted February 15, 2011 Share Posted February 15, 2011 Live = live from mains, load = live to load (heater) that is to say the thermostat interupts the live feed from the mains until the contacts close at a pre set temperature. It's a lot simpler just to buy a plug in "piggy back" thermostat that has a 13a outlet, but since you have already bought a hard wired one........ Quote Link to comment Share on other sites More sharing options...
Soundings Posted February 15, 2011 Author Share Posted February 15, 2011 That is what I thought Antares but what is that N wire? I would have just run the live from the feed to terminal 3 and continues it from terminal 1 to the heater. I would have left Negative and Earth as direct feeds to the plug/power source. Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted February 15, 2011 Share Posted February 15, 2011 I would have just run the live from the feed to terminal 3 and continues it from terminal 1 to the heater. I would have left Negative and Earth as direct feeds to the plug/power source. From the wiring diag. that's what I would have read too and done precisely that, if you are in any doubt have it wierd up by a qualified electrician. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 15, 2011 Share Posted February 15, 2011 That is what I thought Antares but what is that N wire? I would have just run the live from the feed to terminal 3 and continues it from terminal 1 to the heater. I would have left Negative and Earth as direct feeds to the plug/power source. Those thermostats are a simple single pole on/off switch, so contacts 1 and 3 on the diagram act as the switch for the live feed to the heater. So you connect the live incoming brown (live) wire to terminal 3, and the outgoing brown (live) wire to the heater to terminal 1. You then connect BOTH blue "N" (Neutral) wires to terminal 4 and both green and yellow (earth) wires to the un-numbered earth terminal on the stat. As Antaries has said though, if you feel at all confused about it, then it would be safest to leave it to an electrician. Quote Link to comment Share on other sites More sharing options...
Soundings Posted February 15, 2011 Author Share Posted February 15, 2011 It all now makes perfect sense Many thanks Quote Link to comment Share on other sites More sharing options...
quo vadis Posted February 16, 2011 Share Posted February 16, 2011 Please dont do what our old friend Jiffy has done and fixed a gas fired propex in his petrol engine bay Quote Link to comment Share on other sites More sharing options...
Soundings Posted February 16, 2011 Author Share Posted February 16, 2011 Please dont do what our old friend Jiffy has done and fixed a gas fired propex in his petrol engine bay Unlikely seeing as I am talking electric heating on a diesel powered craft. It is hard to believe that somebody actually did that though Quote Link to comment Share on other sites More sharing options...
Guest Posted February 16, 2011 Share Posted February 16, 2011 It does sound a bit extreme, but I don't doubt it. I've seen a few outboard powered cruisers with an Eberspacher installed in the cockpit very close to the (plastic) petrol tank. Quote Link to comment Share on other sites More sharing options...
