loribear Posted March 3, 2011 Share Posted March 3, 2011 hi all we went to the east coast the other day, it was bitterly cold, but noticed that the tide was right out, in fact you could hardly see it because it was that far out, & have noticed it seems to go out that far all along the east coast, so am baffled, WHY if the sea goes out that far does the broads flood so much ? lori Quote Link to comment Share on other sites More sharing options...
diesel falcon Posted March 3, 2011 Share Posted March 3, 2011 hi, the broads is a very large water system and is too big to empty on one tide,hence it dosn,t empty completly if it did you wouldn,t be able to navigate it...hope this makes sense?all to do with volumes of water the figures must be mind boggling!! Quote Link to comment Share on other sites More sharing options...
pks1702 Posted March 3, 2011 Share Posted March 3, 2011 See if this helps The exam is tomorrow http://www.youtube.com/watch?v=aN2RM5wa1ek&feature=related Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted March 3, 2011 Share Posted March 3, 2011 I am sure you are confusing tidal height with the distance it “goes out†as you call it, in shallow areas like the east coast with gently sloping beaches the distance between the high water mark and low water mark can be as much as a click or more but the height difference between those points can be as little as a few metres. This makes no difference to the tidal height when at high water. Conversely if you look at an area where there are sheer rock cliffs the tide may not go “out†or “in†at all but just higher up the cliff, the rise and fall would be the same. Couple that with the Broads being very low lying relative to sea level and you get tidal influence far inland. Just look at the contour lines on any map and it becomes self evident. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 4, 2011 Share Posted March 4, 2011 And add to this, to empty the broads all the water needs to out through Yarmouth too, which is why the currents can be so strong there, it a bit of a bottle neck. Quote Link to comment Share on other sites More sharing options...
loribear Posted March 4, 2011 Author Share Posted March 4, 2011 thanks guys, very interesting indeed, & yes it does sound complicated, & it's nice to see someone from my old neck of the woods, as i was originally from sheffield myself, but now i'm a derbyshan gal. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 7, 2011 Share Posted March 7, 2011 i was originally from sheffield myself, but now i'm a derbyshan gal. Never mind I am actually from Rotherham 10min's from Sheffield, live and work here but most weekends I am in Norfolk. Quote Link to comment Share on other sites More sharing options...
