Sam Posted October 9, 2020 Share Posted October 9, 2020 Looking for a small electric outboard for an 8’ tender. Quote Link to comment Share on other sites More sharing options...
marshman Posted October 9, 2020 Share Posted October 9, 2020 Sam - not questioning your judgement (as if!! ) but don't forget the battery will be heavy, will need to be recharged and lifted in and out of the tender!!! They are not all they are cracked up to be , and if you do not have the facility to recharge it on board, you have to lug it home as well - even a modest size battery is heavy and putting it into the tender can be not be considered the easiest job in the world!! Their appeal is limited in the extreme IMHO There's a very good reason why you don't see that many about on the rivers, but particularly if its a rigid tender you do see lots of oars!!!! 3 Quote Link to comment Share on other sites More sharing options...
Sam Posted October 9, 2020 Author Share Posted October 9, 2020 I wasn’t thinking of lifting it in and out. It can stay where it is. Also getting fuel for a petrol one will be a problem. Just want to be able to start it and go. The tender has oars but I don’t have a young man to use them!! Quote Link to comment Share on other sites More sharing options...
floydraser Posted October 9, 2020 Share Posted October 9, 2020 Yep, Marshman is spot on. If you leave it in the boat you still have to charge it somehow? I had an electric outboard for my 22ft Seal. It worked a treat in use but hauling the battery in and out tests your back muscles and your balance! Of course the ultimate electric outboard is I guess, the Torqueedo, but they are pricey. Quote Link to comment Share on other sites More sharing options...
Regulo Posted October 9, 2020 Share Posted October 9, 2020 We had one for many years, did the job, BUT . . as others have said, unless you get one with an in-built battery (very, very expensive) you have to lug a battery in and out of your tender. We had an 85 Ah one and it is not an easy thing to manage. Even the ones that have inbuilt removable batteries will need a means of charging on board. The batteries are lighter, though. Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted October 9, 2020 Share Posted October 9, 2020 PM sent. Quote Link to comment Share on other sites More sharing options...
grendel Posted October 10, 2020 Share Posted October 10, 2020 if you spend out for lithium batteries, then the battery will be manageable, as they are 1/3 the weight of lead acid for the same capacity, (but 10x or more the price) Quote Link to comment Share on other sites More sharing options...
ChrisB Posted October 10, 2020 Share Posted October 10, 2020 On 09/10/2020 at 12:28, Sam said: I wasn’t thinking of lifting it in and out. It can stay where it is. Also getting fuel for a petrol one will be a problem. Just want to be able to start it and go. The tender has oars but I don’t have a young man to use them!! A little 2.5hp Honda, air-cooled, 4-stroke so no impeller to worry about weighs in far less than a battery. As for fuel a 5 litre can will last for ever on a tender. Tip;- Buy premium fuel it last much longer than normal unleaded and has less of that gummy stuff. Quote Link to comment Share on other sites More sharing options...
Sam Posted October 10, 2020 Author Share Posted October 10, 2020 Hi Chris. I don’t want a pull start and getting petrol on the broads when we don’t have a car would be difficult. Hence the reason for wanting electric. Also as I said before, I won’t be lifting the battery in and out. I will charge it in situ. 1 Quote Link to comment Share on other sites More sharing options...
ChrisB Posted October 10, 2020 Share Posted October 10, 2020 18 minutes ago, Sam said: Hi Chris. I don’t want a pull start and getting petrol on the broads when we don’t have a car would be difficult. Hence the reason for wanting electric. Also as I said before, I won’t be lifting the battery in and out. I will charge it in situ. See where you are coming from. As someone has said and if you are intending to use your tender seriously. For example shopping as you have no car, then the Torqeedo ultralight range are the Rolls Royce and more importantly "work" not just a trolling motor. If however your tender is such that you need to move into the "Travel or Cruise" range then it would be hard to justify their price. EDIT...to say.. If leaving a tender to shop etc...Security is an issue, especially with a bit of kit as desirable as a a Torqeedo. Quote Link to comment Share on other sites More sharing options...
Sam Posted October 10, 2020 Author Share Posted October 10, 2020 All it’s for is crossing the river at Horning possibly once or twice a month. I know everyone meant well and thank you all so much for taking the trouble to reply but I put a lot of thought into it and just wanted something which would do the job. I have been contacted by a member who, hopefully, has just what I need. Again, thanks to all of you. 3 Quote Link to comment Share on other sites More sharing options...
Sam Posted October 12, 2020 Author Share Posted October 12, 2020 The NBN forum member has just been with my ’new’ electric outboard. What a very pleasant young man. So all sorted. Just love this website. 3 1 Quote Link to comment Share on other sites More sharing options...
ExSurveyor Posted October 12, 2020 Share Posted October 12, 2020 1 hour ago, Sam said: The NBN forum member has just been with my ’new’ electric outboard. What a very pleasant young man. So all sorted. Just love this website. Young, flattery will get you everywhere. Have fun with it. 2 Quote Link to comment Share on other sites More sharing options...
