annv Posted November 9, 2020 Share Posted November 9, 2020 Hi Floyd I guess you want to use fresh water flush to stop that nasty smell you get when using it for the first time, we have a fresh water flush on this boat for that reason! i would suggest that you plumb it in from the pumped pressure supply this means it will only work when pump is on also run the pipe up above the toilet then down through a non return valve supplied from LeeSan this will prevent any water running back and will prevent any possible contamination issues we have had no issues since we have adopted this in nine years it is nice to use it without that nasty smell you had when first using it, also the toilet stays cleaner, on our other boat i fitted a dispenser unit in the inlet pipe from the river surpled by LeeSan worked very well except it was expensive for the amount of tablets it used they didn't seem to last long but no smell and colored water flush, wife was happy my wallite wasn't. John 1 Quote Link to comment Share on other sites More sharing options...
annv Posted November 9, 2020 Share Posted November 9, 2020 Hi Fishfoxy I guess you want to use fresh water flush to stop that nasty smell you get when using it for the first time, we have a fresh water flush on this boat for that reason! i would suggest that you plumb it in from the pumped pressure supply this means it will only work when pump is on also run the pipe up above the toilet then down through a non return valve supplied from LeeSan this will prevent any water running back and will prevent any possible contamination issues we have had no issues since we have adopted this in nine years it is nice to use it without that nasty smell you had when first using it, also the toilet stays cleaner, on our other boat i fitted a dispenser unit in the inlet pipe from the river surpled by LeeSan worked very well except it was expensive for the amount of tablets it used they didn't seem to last long but no smell and colored water flush, wife was happy my wallite wasn't. John 1 Quote Link to comment Share on other sites More sharing options...
Jbx5 Posted November 9, 2020 Share Posted November 9, 2020 Fresh water flush every time after having the last 2 boats river water flush. Our current boat has a huge water tank and was built with fresh flush so may not work successfully with a smaller tank or retro fit. I know when we have been out with our daughter when they have hired a broom 30 (fresh water flush) they had to fill up a lot more than us. John Quote Link to comment Share on other sites More sharing options...
