Guest Posted April 21, 2011 Share Posted April 21, 2011 Hi Gang, I am going down to "Tango this weekend with the Intention of re-glueing all the front cabin wall coverings and will need to open the escape hatch which appears to have been sealed down! I guess water Ingress was the reason. How hard is it to replace the rubber seal to make it water tight ? Quote Link to comment Share on other sites More sharing options...
VetChugger Posted April 21, 2011 Share Posted April 21, 2011 Totally depends on the eventually bare surfaces that meet and, of course, the integrity of the hatch itself. The rubber seals are readily available in many many different forms from Seals+Direct and if you email them they will send you samples. These are not difficult to use and achieve good water tight results. http://www.sealsdirect.co.uk/bbCMS/bbCMSrenderPage.asp Trevor www.normanboats.co.uk Quote Link to comment Share on other sites More sharing options...
jimbo Posted April 21, 2011 Share Posted April 21, 2011 Thanks for posting that link Trevor, I can see a shopping list looming Quote Link to comment Share on other sites More sharing options...
Guest Posted April 21, 2011 Share Posted April 21, 2011 and will need to open the escape hatch which appears to have been sealed down! It would fail the BSS as well if the escape hatch was inoperable... Quote Link to comment Share on other sites More sharing options...
VetChugger Posted April 21, 2011 Share Posted April 21, 2011 If you tell Phil at Seals+ that Trevor from the Norman site sent you there MAY be a bit of a discount! Trevor www.normanboats.co.uk Quote Link to comment Share on other sites More sharing options...
Guest Posted April 21, 2011 Share Posted April 21, 2011 If you tell Phil at Seals+ that Trevor from the Norman site sent you there MAY be a bit of a discount! Trevor http://www.normanboats.co.uk I knew a bloke called Norman once and he wasn't at all boring. Just shows you can't generalise! Quote Link to comment Share on other sites More sharing options...
