Antares_9 Posted May 25, 2011 Share Posted May 25, 2011 Possibly not quite so important for those in the fresh water bits but well worth a look for the rest of us. http://www.ybw.com/forums/showthread.php?t=268741 Quote Link to comment Share on other sites More sharing options...
Palmtree Posted May 25, 2011 Share Posted May 25, 2011 Hi, I found this sometime ago and indicates the problem has been around for a few years as the yacht was 7 years old and the part was fitted from new. http://www.michel-christen.com/2T-H.pdf Ian Quote Link to comment Share on other sites More sharing options...
senator Posted May 25, 2011 Share Posted May 25, 2011 does this mean that the insurance company's will deem that you have failed to maintain your boat correctly if one of these cheap fittings, fitted from new, fails and sinks your boat? Quote Link to comment Share on other sites More sharing options...
pks1702 Posted May 25, 2011 Share Posted May 25, 2011 On a similar vein I posted this the other week viewtopic.php?f=3&t=10447&p=126207&hilit=seacocks#p126207 Quote Link to comment Share on other sites More sharing options...
pks1702 Posted May 25, 2011 Share Posted May 25, 2011 This one is running on the other side too http://www.ybw.com/forums/showthread.php?t=274579 Apparently the article authors wrote to various boat manufacturers to ask how they could justify fitting brass fitting, none of the yacht manufacturers responded, however they did also write to Sealine who did respond, they offered the justification that the brass fittings will last the 5 years prescribed in RCD ISO 9093-1, (but this 5 years does NOT take into account electrolytic action which accelerates the rate of dezincification... ) Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted May 25, 2011 Author Share Posted May 25, 2011 Very probably Ian, though I suspect for later vessels one could argue latent design fault which is usually covered. I had forgotten about that Perry, a useful reminder. I reckon I might well look at some glass filled plastic fittings on the next lift out, though I have always given my through hulls a good sideways tap to check at each lift out. Given that the RCD only expects a five year life they look like a service item now, better be safe than sunk. Quote Link to comment Share on other sites More sharing options...
Palmtree Posted May 25, 2011 Share Posted May 25, 2011 does this mean that the insurance company's will deem that you have failed to maintain your boat correctly if one of these cheap fittings, fitted from new, fails and sinks your boat? I think ( and will check later in the week) ISO 9093-2:2002 - Small craft -- Seacocks and through-hull fittings gives the life of a fitting as minimum 5 years, so I suppose now you have raised it the insurance company might say it is a failure of maintenance. Ian I think I have just been Lakesailored! Quote Link to comment Share on other sites More sharing options...
Antares_9 Posted May 25, 2011 Author Share Posted May 25, 2011 I think I have just been Lakesailored! Only a bit Ian , in a recent nameless incident the insurance company refused to cover it as corrosion of underwater fittings is specifically excluded from most policies. Quote Link to comment Share on other sites More sharing options...
