Mud Weight Dragging
Andrewcook
16 minutes ago, stumpy said:
I've always found Salhouse to be poor holding as it's a sand bottom rather than bottomless black mud - tucked up in the corner Wroxham end seems the most sheltered.
Yeah, Salhouse has always been a bit of pain in that regard. We've often had problems at forum meets with a whole line of boats moored stern on but sitting diagonally because of a strong wind.
With most of the other Broads, give it a good lob and it sinks nicely into the mud. The conical design of a mudweight is deliberate so that a gentle pull (such as from the weight of the boat) will not dislodge it.
Places like Womack have mud so sticky that most of the time you have to tow the mudweight off with the boat and then leave it at the surface for a couple of minutes when under way to get it clean.
What is the best way to "lob" a mud weight. Employ a Geoff Capes stance at the bow with said mud weight under chin. (Some might prefer a bit of a "run up" along the deck).  The SL approach is favoured by some. The Swinging Lob for the uninitiated. Stand with feet apart and swing the said mud weight by the attached rope in ever increasing momentum. Having reached optimum velocity and desired projection one lets go. The mud weight should quite literally sail through the air. Where it ends up is a bit of a lottery, in the bobbing up and down stuff, or the windshield. Do not under any circumstances delegate this task to a crew member of limited vocabulary as his reaction may upset crew members of a nervous disposition in the latter being the result.
There you have it. For me a gentle lower, in consideration of my dear wife who will be tasked in lifting it up and out.
Old Wussername
  • Haha 2
Let out plenty of rope. It allows the pull on the weight to be more horizontal through the mud, with a better chance of holding.
Agreed.  Letting our plenty of rope is otherwise known as 'Scope'
If you plan to do a fair amount of mudweighting, ask the yard to provide a second one.  We always take a second mudweight for the Jewels every October,  H.W's are happy to provide.  We also have a secondary one permanently onboard 'B.'A too
We do the same Griff and store the additional weight in one of the upper lockers.
I always carried two mud weights and a 2mtr length of chain shackled to a Danforth  which could in turn be shacked to the eye of the mud weight.
We rode out a real overnight blow using the above but the mess on deck on retrieval had to be seen, in fact not only the deck over me as well.
to be fair Chris, if you are on a hire boat none of those options will be available to you, so Andrew, its always worth asking for a second mudweight, if its windy, dont deploy them fore and aft as if the wind direction changes they will pull out, but stick them both off the bow fairly close together, and with plenty of slack, and check you have a boat length to swing with the wind in all directions.
1 hour ago, OldBerkshireBoy said:
People say to throw the weight rather than drop it but how can you do this solo with an electric winch?
I think most electric winches (my Lewmar certainly does) allow it to free drop, i e you dont "winch out".
There is no point in throwing a mud-weight when mooring in a broad, you can let out all the scope and motor gently in reverse, which will also help to dig it in.
If it is your own bot, then don't use rope, replace it with 100% chain if you have a winch with a chain locker, then let out 3 times the depth and it will lie along the bottom and not drag.
18 hours ago, ChrisB said:
If you have room to stow it, a Bruce on chain is great for mud. Better than CQR imho. I would reverse that if you are in clay however.
Yep,  Bruce is a good anchor, I use one myself with two metres of chain on the end of my anchor warp. However, the Bruce is very good at snagging obstacles on the river/broad bed and I always use a tripping rope  secured to the small hole on the knuckle of the anchor so that I can retrieve it easier. The tripping rope should be attached to a small buoy or even a plastic drinks bottle to stop it fouling the main anchor warp.
The reason you should throw/swing a mud weight by hand is to stop you being bitten ie the splash of water that you get in the face if just dropped, by swinging it away from you the splash is directed away from your face/body, letting down slowly could give you a rope burn to the hands. John
