Polly Posted April 22, 2021 Share Posted April 22, 2021 It’s a Skoda Octavia 2019 model. There are 4 rear parking sensors and one is bleeping red with nothing behind the car. I cleaned it with WD 40, even tried a hairdryer on it. This has come on since I jet washed the car last weekend. My brother suggested covering it with duck tape, and that has worked as a temporary fix. Any ideas for a more permanent solution? Help? 😘 Quote Link to comment Share on other sites More sharing options...
Chelsea14Ian Posted April 22, 2021 Share Posted April 22, 2021 Any advice in the hand book or checking with Skoda? Quote Link to comment Share on other sites More sharing options...
Polly Posted April 22, 2021 Author Share Posted April 22, 2021 None in the handbook. I rang the garage, they said book it in....now that is a last resort because the ££££££ implications are a definite thing with that dealership. 1 Quote Link to comment Share on other sites More sharing options...
NeilB Posted April 22, 2021 Share Posted April 22, 2021 We had a 3 year warranty on our Skoda, is yours still covered? Quote Link to comment Share on other sites More sharing options...
marshman Posted April 22, 2021 Share Posted April 22, 2021 Polly - do you live in the Norwich area? Pop into Das Auto, Blue Boar Lane, behind the Social Club - lovely bunch of lads who are VERY fair!!! Quote Link to comment Share on other sites More sharing options...
Mouldy Posted April 22, 2021 Share Posted April 22, 2021 1 hour ago, Polly said: This has come on since I jet washed the car last weekend. My brother suggested covering it with duck tape, and that has worked as a temporary fix. Any ideas for a more permanent solution? Help? 😘 Fairly certain it will be water ingress as the result of pressure washing. I occasionally get this when I’ve washed my Octavia, but it usually goes away after a couple of hours. I fear that applying WD40 may have made it worse, but covering it with duct tape will make the sensor believe that there is something there and will not improve the issue. Skodas are covered by a three year warranty, so going to your local agent would be best. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted April 22, 2021 Share Posted April 22, 2021 Duck tape will also hinder it drying out. 1 Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted April 22, 2021 Share Posted April 22, 2021 Park the rear of the car in sunshine and dont blast the bumper with a jet wash again. Quote Link to comment Share on other sites More sharing options...
floydraser Posted April 22, 2021 Share Posted April 22, 2021 This is just one reason I never use a jet wash. The others being the noise, the faff with the electrics and the fact that a normal hose delivers more water quickly. A quick pre-rinse softens any mud which will then come off easy with a brush. Jet wash around the engine can also cause belts to slip. I used to have one but binned it as a waste of time. Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted April 22, 2021 Share Posted April 22, 2021 WD40 should never be used on any form of electronics, as already stated it causes more problems than it fixes. Quote Link to comment Share on other sites More sharing options...
floydraser Posted April 22, 2021 Share Posted April 22, 2021 32 minutes ago, ranworthbreeze said: WD40 should never be used on any form of electronics, as already stated it causes more problems than it fixes. I never knew this stuff existed until I went looking for something to clean the sliding volume controls on an old Bontempi organ: https://www.screwfix.com/p/wd-40-specialist-contact-cleaner-400ml/92716 Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted April 22, 2021 Share Posted April 22, 2021 I always recommend no sprays of any kind they always leave a residue. Quote Link to comment Share on other sites More sharing options...
Mouldy Posted April 22, 2021 Share Posted April 22, 2021 9 minutes ago, ranworthbreeze said: I always recommend no sprays of any kind they always leave a residue. I think in this case it will have sealed the moisture in, rather than let it evaporate away. Quote Link to comment Share on other sites More sharing options...
Polly Posted April 23, 2021 Author Share Posted April 23, 2021 🙄So I went to Indispension in Northampton this morning and they traced the fault. It was in my brain!! The towbar cap was a bit skewed and the sensor was picking it up. 🤪🤪🤪🤪🤪🤪🤪🤪 9 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted April 23, 2021 Share Posted April 23, 2021 Fine example of 'Learn by do method' As in - I'm not gonna do that again ! Griff 1 Quote Link to comment Share on other sites More sharing options...
Polly Posted April 23, 2021 Author Share Posted April 23, 2021 You bet! Quote Link to comment Share on other sites More sharing options...
RumPunch Posted April 23, 2021 Share Posted April 23, 2021 Hmmm - has anyone fitted reversing sensors to a boat I wonder .......... Quote Link to comment Share on other sites More sharing options...
Smoggy Posted April 23, 2021 Share Posted April 23, 2021 6 minutes ago, RumPunch said: Hmmm - has anyone fitted reversing sensors to a boat I wonder .......... Yes, it makes a crunching sound when you run out of space.... 3 Quote Link to comment Share on other sites More sharing options...
annv Posted April 23, 2021 Share Posted April 23, 2021 W D is a dispersonce it just moves the water from a to b widely used in 60's 70's by AA, R A C and breakdown's on cars, on distributor caps, plugs etc to get you going and move the problem elsewhere it does have it's uses but not on electric's. John Quote Link to comment Share on other sites More sharing options...
SteveO Posted April 23, 2021 Share Posted April 23, 2021 32 minutes ago, RumPunch said: Hmmm - has anyone fitted reversing sensors to a boat I wonder .......... I fitted a reversing camera to mine. Works a treat. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted April 23, 2021 Share Posted April 23, 2021 Reversing camera on a boat? Adjust one’s field of vision normally via neck muscles. Engage Port n Stbd look outs and look aft Unless one is helming a bathtub of course Griff 1 Quote Link to comment Share on other sites More sharing options...
WherryNice Posted April 23, 2021 Share Posted April 23, 2021 My Safari might sprout a reverse cam at some point but it's quite a way down the list behind such things as an engine that runs properly and windows that don't leak......etc etc Quote Link to comment Share on other sites More sharing options...
