Nanni 3/90 Identification
Just a long shot but can anyone tell me which Kubota engine the Nanni 3/90 is based on?
I need some parts which Peachments are quoting weeks on for delivery and I have tried half a dozen other suppliers around the country only to discover they all use Peachments!
Help! :default_sad:
If you go to kubta stockist ie industrial parts stockist/importers with the engine no you should be able to get what you want BUT they will only know about the base engine not the addons that are marinize parts ie heat exchanger, impeller, raw water pump,oil extractor pump, larger/additional alternator, what is it you want. John
Thanks John. It's oily bits I am after which is why I am traveling the Kubota route.
2 hours ago, grendel said:
d650b, d750b, d850b, d950b
70mm stroke series engines
Perfect. That's got me close enough to be able to cross reference the numbers.
Parts located!
Yay!!!
If its the fuel and oil filters you need any car/van factors will be able to supply by cross referencing  the part number that is  on your filters the ones listed by Kubota may not be the same size as you have fitted there are lots of filters that have the same/correct specification but can be longer shorter wider depending on what is needed to clear added ancillary equipment which requires a different size filter. John
If a fuel injector pump it would have to be a Kubota model one that is designed for that engine, there can be many different applications/ output on the same basic pump. not necessarily made by Kubota       Bosch ,  Cav ,Simms etc  look for makers name and part number on pump body along with engine number then go to injector/pump specialist they may refurbish yours or ba able to supply a exchange unit. John
well thta will teach me, it was a head gasket, its on order and I may be putting in for a pit stop to have it swapped over mid holiday. the injector pump issue has been resolved for now, by adopting a new procedure called shut off the fuel when not running the engine.
yes the pump can be refurbished, it was just a time issue with me being due to take the boat out tomorrow.
