RAY OF LIGHT HERBERT WOODS
Guest CIMLAJACK
Looks to me like a Faircraft Loynes build (when they were part of the same group). Not been on but I reckon it will be a top spec boat, probably a low wash hull, will probably go along very well indeed. Faircraft Loynes actually build their own engines which run very smoothly. It will be a good boat. Only downside I can see is the air draft, Potter, Wroxham and Beccles old bridges will most likely be out, as Wayford and Thorpe. Bit of extra care needed at Great Yarmouth too. Ludham should be OK but again wise to double check when approaching.
cheersbar
